VATS bypass?
Old Jan 12, 2004 | 02:54 PM
KBoogie's Avatar
Default VATS bypass?
Ok, my car is almost done, and i need to be able to get it started. And considering i foolishly went out and spent the money i had saved for my LS1 Edit...... i need to know where i would be able to find a VATS bypass module. I looked on Bakerelectronix.com , and they told me that they were not sure if it owuld work on a 99 LS1, because they switched over to a "Class 2" or a serial based anti theft system. I will copy and paste the e-mail he sent me so hopefully someone her can help me get my car on the road untill i can save up another $550 for LS1 Edit.
Thanks!
KB
Kyle,
Unfortunately, I don't know. From 98 up to 01 the LS1s were changing over to a newer anti-theft system called Class2 or serial based it depends on what model of vehicle your PAM/engine computer came from. Our VATS modules only works for those Pumps that have a dark blue wire on the RED or 'C2' connector of the PAM that is labeled 'VATS' or 'Fuel Enable', usually in pin position 25 or 30.
Let me know if you have anymore questions.
Neil Baker
Baker Electronix
Old Jan 12, 2004 | 04:04 PM
Speartech's Avatar
9 Second Club/LS1TECH Sponsor
Serial data VATS is used on Vettes and trucks.
If your PCM is from an F-body it uses the earlier PWM VATS.
__________________
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
Old Jan 12, 2004 | 05:02 PM
KBoogie's Avatar
So even tho i am using a diff fuel pump on a diff circuit with a seperate relay, will this work? I am using all parts from Hinson Supercars. I do plan on getting LS1 Edit.... but i was thinking i would just get a bypass for now.
KB
Old Jan 12, 2004 | 05:31 PM
Speartech's Avatar
VATS has nothing to do with the fuel pump or relay. VATS enables or disables the fuel injector pulses from the PCM.
All that pump and relay stuff is just bad internet info.
__________________
www.speartech.com
Old Jan 12, 2004 | 09:35 PM
KBoogie's Avatar
Thanks alot John. Your input is really helping me. Can you tell me if this would work for my car??
http://mysite.verizon.net/vze7erz1/id1.html
Thanks again!
Kyle Buchanan
Old Jan 12, 2004 | 10:23 PM
Speartech's Avatar
I don't know anything about that place, but if your using an F-body PCM that type of thing will let the engine start.
__________________
www.speartech.com
Old Jan 12, 2004 | 11:18 PM
KBoogie's Avatar
Ok. Do you know of any VATS bypass modules?
Thanks!
KB
Old Jan 13, 2004 | 08:01 AM
Speartech's Avatar
No I don't. We always turn it off with PCM reprogramming here.
__________________
www.speartech.com
Old Jan 13, 2004 | 12:55 PM
onehardmaro's Avatar
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2453786168
Im not selling it but they are ebay often.
One of the links on this page shows you how to make one.
https://ls1tech.com/forums/new-ls1-owners-newbie-tech/87186-how-websites-thread.html
Old Jan 13, 2004 | 07:08 PM
Gen3Benz's Avatar
the guy i bought my eng/trans from gave me one
it still has the price tag on it, ill sell it for $30 shipped, they paid way more for it.
easy to hook up, three wires, just a 5v and ground
then the signal wire to the pcm, its a 50hz fake bcm signal
Old Jan 14, 2004 | 04:16 AM
67pete's Avatar
If I understand this right .. the VATS system operates off of the ignition switch with a special key. Can't you get a new key and/or switch made up for the existing code? The engine and computer are from a donor car no longer in service so can't it be replaced from the dealer? This would allow one to keep the anti theft device which seems to be more important every day.....
Old Jan 14, 2004 | 07:13 PM
Gen3Benz's Avatar
the key has a resistor pellet,bcm sends power to it, if it gets the right voltage back, then it sends a 50hz signal to pcm to run the injectors.
you could just make the vats module easy to disconnect, then the car would not run without it. much easier security system.
