Oil Pre-Luber
http://www.aaeq.net/files/file/Instr...heets/pl40.pdf
seem like a good product to use ($35.00 ?), wonder how easy it would be to build one !?
That's 'cuz we pre-oil w/ Accusumps or full time pre-oilers. The unit in your link is only a before you start the engine pre-oiler. An Accusump or permanently installed pre-oiler also protects under high G cornering by adding oil & maintaining oil pressure when oil pressure drops.
My intent on this thread was to let people know of this low cost Pre-luber that is on the market.
With all of the countless past threads I have read on the subject of dry startup, its concerns and the many crazy way of getting oil pressure prior to 1st startup.. (ie. pulling the fuse and cranking over till there is oil presure, over filling the oil, tilting the car/engine up to get oil to flow into the pickup and pump). This seem like a good one time low cost alternative or for any shop to have.
I have also read the one artical they did in Car Craft of using a 5 gal bucket, a old SBC oil pump, some hoses and fittings and a electric drill..
I think the percentage of people that would need to use the Moroso or Canton Accusumps oil Accumulators would be a very low percentage.. not that it isn't a great product and useful when needed...but I guest for the 90+ percent of us on this forum, it's Overkill (IMO and my 2 cents).. but then again, that what we car people love to do.. ! LOL
IIRC I posted a link on this very subject before. It might be eaiser just to go to CC's site and do the search.
An accusump provides pre-oiling to the engine on start up and it also stores oil for surge protection as well.
Say you make a 1/4 mile pass and your engine loses pressure on shut down.
The accusump will discharge the stored oil into the engine so that the engine can maintain oil pressure and keep the bearings and etc lubricated.
If you have any questions about the accusump feel free to ask me man.
http://www.homedepot.com/webapp/wcs/...7&ddkey=Search
Second thing, the installation guide GM sends out with their LS crate motors doesn’t require a pre luber. They say to just crank it over without starting it until you see oil pressure.
http://paceperformance.com/ProductIm.../LS376-515.pdf
filled with the appropriate motor oil to the recommended oil fill level on the dipstick. The LS376/515 crate engine
requires a special oil meeting GM Standard GM4718M (this will be specified on the oil label). Mobil 1 is one such
recommended oil. Other oils meeting this standard may be identified as synthetic. However, not all synthetic oils
will meet this GM standard. Look for and use only an oil that meets GM Standard GM4718M. Also check and fill
as required any other necessary fluids such as coolant, power steering fluid, etc.
2. The engine should be primed with oil before starting. Install an oil pressure gauge (the existing oil pressure sensor
location at the upper rear of the engine may be used). Disconnect fuel and the ignition control system (removing
power from the ignition control module is recommended). Note: Be sure that neither fuel or ignition can be provided
to the engine.
3. Once the fuel and ignition control systems have been disconnected, crank the engine using the starter for 10 seconds
and check for oil pressure. If no pressure is indicated, wait 30 seconds and crank again for 10 seconds.
Repeat this process until oil pressure is indicated on the gauge.
I'm sure anyone can rig up some back wood contraption and it will work just find.. The CC Mag is just one attempt that will show you anything can work. even using a bucket and an old SBC oil pump.
But as Pop posted, GM doesn't even pre-lub...
