2001 S-10 LSx Swap
Old Jun 21, 2010 | 04:16 PM
04600rr's Avatar
stevekeller.......you need to visit s10forum and read about the swap. if you have the 4.3 with nv3500 you can use it in the swap.
Old Jun 21, 2010 | 05:36 PM
RTRx7's Avatar
You guys like some fast trucks...
Old Jun 25, 2010 | 10:25 AM
black05stxjt's Avatar
any idea when the in frame headers will be ready for production?
Old Jun 25, 2010 | 11:58 AM
fenton06's Avatar
Do you have a conversion kit for 93+ 2WD S10's?
Old Jun 25, 2010 | 12:51 PM
BRPhotrods's Avatar
They are being mocked-up at Hedman, it shouldn't be more than a couple weeks before they are building them, and then about another week for them to be coated. We are going to ask them to build atleast 10 sets on the intial production run, as soon as they have them mocked-up I'll post pics and as soon as they are done coating we'll have them available.
Jeff
What year is your truck? We have a 1st gen kit and a 2nd gen kit.
Old Jun 25, 2010 | 01:01 PM
Petraszewsky's Avatar
Jeff
YES!!! Are these the 1 7/8 or 1 3/4 inside the frame???
Old Jun 26, 2010 | 01:45 PM
fenton06's Avatar
It is a 98 ext cab, I was just asking because I didn't see any info on your website about 93 and newer trucks.
Old Jun 28, 2010 | 08:05 AM
BRPhotrods's Avatar
They are trying to fit the 1 7/8" inside and believe that they can.
Jeff
Old Jul 25, 2010 | 10:05 AM
any updates???
Old Jul 26, 2010 | 10:10 AM
BRPhotrods's Avatar
any updates???
The coversion kits are back from being powder coated and are getting boxed up today. The headers are taking them a little bit longer than expected. As soon as they have them finished I'll post them up.
Old Jul 26, 2010 | 10:18 AM
will the headers just be available in ceramic or painted or both?
Old Jul 27, 2010 | 08:23 AM
  #32
BRPhotrods's Avatar
We will be offering them as coated headers, but they can ordered uncoated. The right header is done and they are building the jig for it. The driver's header is being built, on the late model you will have to relocate the proportioning valve to make room. We will have detailed instructions on how to bend the lines aand where to place them in the instructions.
Old Jul 27, 2010 | 08:29 AM
  #33
thanks for the info is the kit going to be in the same price range as the first gen kits?
Old Jul 27, 2010 | 10:07 AM
  #34
BRPhotrods's Avatar
Yes the pricing is the same as the first gen kit. Here's a couple pictures of the headers during mock-up. The tab on the bottom of the tubes will not e there on the production headers, but the mock-up header needs it on the bottm while the jig is built.
Attached Thumbnails 2001 S-10 LSx Swap-img_0044.jpg   2001 S-10 LSx Swap-img_0020.jpg
Old Jul 27, 2010 | 10:52 AM
  #35
looks great cant wait for them to go to full production so the mount kit will be 489 judging from yalls site what will be the price on the headers?
Old Jul 28, 2010 | 12:42 AM
  #36
Alvisracn's Avatar
What do they look like from the engine compartment and are they all one piece or slip fit?
THX
Old Jul 28, 2010 | 08:12 AM
  #37
BRPhotrods's Avatar
The headers come ceramic coated. The mid length will be $499, the 1 3/4" long tube headers will be $669. As you can see in the pictures these are inside the frame long tubes. The only mods to the vehicle will be the body seam on the passanger side has to bent flat and on the driver's side the prop valve needs to be reloacted under the master cylinder. I bent the 90 degree lines from the master cylinder to preop valve 180 degrees (into a U shape), removed the bracket from the prop valve and re-installed the lines. We are putting a section in the installation guide the shows you how to do it in detail. The header come with a bolt-on collector (slip-fit) and one fo the tubes is cut free from the other to make installation easier on the passanger side. I'll go through the pictures and find one from the top side and post it when I can log-on the computer that has all of our photos on it.
Old Jul 28, 2010 | 08:22 AM
  #38
BRPhotrods's Avatar
Here's a picture from the engine compartment of the mock-up header on the passanger side. I've also enclosed a before and after showing what I did to the prop valve.
Attached Thumbnails 2001 S-10 LSx Swap-img_0025.jpg   2001 S-10 LSx Swap-img_0026.jpg   2001 S-10 LSx Swap-img_0039.jpg
Old Jul 28, 2010 | 12:09 PM
  #39
jmd's Avatar
jmd
Good thread, Jeff. Thanks for sharing all that you have.
I plan on doing a 5.3 swap in a 94 reg cab S-pickup in the future but it's 4x4.
Old Jul 28, 2010 | 12:41 PM
  #40
Will there be any mods to the dipstick tube??
