fox body ls1 t56 conversion
Old May 31, 2010 | 09:58 AM
92ls1notch's Avatar
Default fox body ls1 t56 conversion
i am putting a ls1 t56 into my 1992 notch back and i am having some problems finding info on how to set up the clutch master...whether i have to get diff pedals? or i can mod my pedals to work.....any info would be great and pics would be even better....thank you
Old May 31, 2010 | 12:02 PM
Miles.'s Avatar
Try to find a 87-88 Turbo Coupe pedal assembly. They are the only fox cars to have a hydraulic clutch system.
Old May 31, 2010 | 12:23 PM
72Elkytpi's Avatar
You can modify your pedals. Remove the pedal assembly and get rid of the quadrant and cut the housing. Get a tilton 3/4" master cyl from summit and bolt or weld to firewall then mount reservoir to engine side of firwall
Old May 31, 2010 | 06:21 PM
92ls1notch's Avatar
will the 87-88 turbo coupe pedals bolt right up with no mods and will i be able to use the fbody master or do i need a universal master
Old May 31, 2010 | 06:24 PM
92ls1notch's Avatar
what do you mean cut the housing....i have the whole pedal assy out....i saw a pic on a lq4 t56 build but i was fully sure why that was done
Old Jun 1, 2010 | 12:18 AM
Miles.'s Avatar
I think at most to get it to bolt up you might have to elongate the mounting holes. The most popular way I've seen for the master cylinder was to use a universal master.
Old Jun 1, 2010 | 07:50 PM
92ls1notch's Avatar
now the hard part is finding a set of turbo coupe pedals
Old Jun 2, 2010 | 02:12 PM
GlennNo50's Avatar
I found mine on a turbo coupe forum. Just google "Turbo Coupe". Should be one of the first ones to pop up. There are usually a few being parted out. I registered and posted a want ad and had a couple of responses.
Old Jun 2, 2010 | 07:23 PM
92ls1notch's Avatar
ok thanks for the input..hopefully i can get one soon
Old Jun 2, 2010 | 08:11 PM
getsum27's Avatar
i used a stock fbody master and i used my stock pedals........... i quit listening to all these people who kept tellin me to spend the money on pedals then spend money on a universal.............
if you cut off where the quadrant goes on your stock pedals and lay them on a bench it will all come to you man........ didnt cost me a dime...... but probly 4 hours of work by the time i was done
Old Jun 2, 2010 | 10:27 PM
92ls1notch's Avatar
yea a buddy of mine might have a fbody master laying around so i can see if i can fab it up....it would be alot nice if i could just use my foxbody pedals......now when u say cut the quadrant off what do u mean?.... my quadrant slides onto two posts and then a clip holds it in.....did u have to fab up a stop for the pedal?
Old Aug 3, 2013 | 06:34 PM
Fri Guy's Avatar
Any update on this topic? I'm also looking into doing a T56 swap when I do the LS swap on my fox body mustang.
Old May 4, 2015 | 09:23 AM
tschellinger2's Avatar
Default hydraulic clutch conversion
Just use the mcleod hydraulic clutch conversion kit, and you won't have to dick around with stock pedal assembly. Order it without their throwout bearing, and just use the stock fbody stuff. Easiest way I found to make it work.
Old May 15, 2015 | 10:40 PM
ls13ater's Avatar
I just finshed my swap went from a 4l60e to t56, I used wilwood 7/8 master slave, -3an line, 87-88 tb pedals, I cut and fab a bracket for the master to be mounted under the dash, the back off the master sticks threw the fire wall right above the steering link, you have to cut your boot, my engine is mounted very fare back so I had to trim the floor for the shifter to slide threw, i just walk in from taking it in my first test drive!!!!
Old May 17, 2015 | 09:08 PM
Nosboy's Avatar
I have a 91 notch with a 6.0 with a 4l70e trans. I really want to swap to a t56 but I am worried about it fitting in the stock location. Has anyone done this successfully? Thanks guys!
