63 belair ls conversion,supercharged!
custom driveshaft heavy walled 2" shaft with billet carrier bearing.slip yolk in the rear like it should have been from the factory all new a year and a half ago has about 5,000 mile on it. paid $675 sell for 400 shipped
still have the driveshaft I will check on the slip on it
Still have the driveshaft? How much slip does it have?
yes the pump that I first used is a corvette, the one that is on it now is off a camaro both worked fine.
VIDEO OF OUR DRAG STRIP ADVENTURE!
You will see the 11's next time for sure. Seems to need more revs off of the line and maybe some dedicated tires for the higher stall launch. Turn the wick up on the turbos also!!! Great job and glad you made it home in one piece. A true sign you built a complete package.
thanks for the interest going to replace the rear suspension this winter. new arms ,shocks,brakes ect.ect.I will just make everything from scratch. thanks for the offer though.
https://ls1tech.com/forums/conversio...ing-broke.html
Dw2WzxSGAdo
Dw2WzxSGAdo
