LS1/t56 73 Corvette 12/1/10
If that doesnt work for you, Street and Performance has adapters which would allow you to use your original temp sender and plug it into the LS block. May not be ideal, as the sender will be outward of where its intended position would be, but your temp gauge will be working.
B.
can you post some pics showing the clearance between the back of the engine and the firewall? also curious about clearance of the accessories and the steering box & front crossmember. I've been collecting parts for a LS1 conversion in my 73 too. Plan on pulling the engine and trans this fall.
if you dont flash out the rear o2 sensoers it will throw a code for sure but i dont know if it will derate or anything. you will need to flash out other stuff with it. if at all possible get a tune for it, mail order or dyno, and they should be able to get rid of the stuff you dont need
This is the intake compared to the radiator
This one was suppose to show the back of the block to the firewall. Its about 2 to 1 1/2 inch space
This was suppose to show the header space,but didnt come out well, but there is quite a alot of space. Im better long tubes might work but i played it safe and got block huggers, should be here tomorrow
This is the shifter location. I believe it came out quite perfect
There is alot of sapce for the fans and the space between the engine and front crossmember. And by the way those are fans from a c5 vette
I got my headers today they are 68520 - Hedman Hedders Street Rod Block Hugger . Ill post pictures tomorrow but if anyone has doubt about he fittment on the c3 for headers these clear very well are very lightweight.
congrats on firing it up. As far as VATS goes, you need a tuner package (I've been using LS1Edit; bought it 10 years ago) to turn it off. Hard to tell from your videos but is the engine starting and dying as soon as you turn the starter off?
http://cgi.ebay.com/ebaymotors/GM-VA...Q5fAccessories
#32
engine, trans, radiator, & fans from a 2000 camaro
PCM
DBW module, gas pedal,& matching throttle body
C5 oil pan
C5 exhaust manifolds
C5 body control module
a couple of engine harness to build a donor harness
other odds and ends
while the engine & trans are out of the car I am installing a Vintage Air setup and do a Jeep power steering box conversion. Figure I will get it going by next summer.
#36
#38
Thanks for the offer. so far I have:
PCM
C5 oil pan
other odds and ends
PCM
C5 oil pan
other odds and ends
#40
thanks for the offer but I have all the wiring diagrams I need. just waiting till October before I begin. Actually I've been tuning the 383 with a wide band O2 and playing with the A/C. Guy at work GAVE me a 30# bottle of R-12. I'm getting 50 degF air out of the upper A/C duct but I am pretty sure I remember seeing a half-dollar size hole in the bottom of the evaporator housing the last time I was under the car. Going to get under it this weekend and take a look.
