Ly6 or LQ4/LQ9
I can't really find what i'm looking for and maybe you guys can help me out here.
Ly6 and L92. Is L92 an engine or is it just the heads that come on and LY6? I'm going to put the Ly6 in my Malibu or a grand national roller I'm trying to trade my Malibu for. For better flow in an intake and potential to make more power should i swap my intake for a LS3 intake? I'm guessing my TB from the truck intake will fit on the LS3 intake. I'm planning on running a turbo but for now to get the swap done i'm just going to put the motor and 4L80E in and drive it like while i save up for the turbo.
Yes i am very new and have been looking for the info but haven't found what i'm looking for. I'm sure the info is in front of me but for whatever reason i can't seem to find it. My flame suit is on so i'll take all criticism with a grain of salt.If any of you guys have links to what I'm looking for I'm more then happy to read them and figure it out but a direction would be greatly appreciated.
Thanks
Austin
half the guys that make some of these comments have no clue to actual valve timing events, whats optimal, and whats not...
People are still using carbs and not utilizing fuel injection either....I know, this new fangled magic is scary!
Don't mind me...I’m just biased and tend to embrace technology, the low end and top end efficiency of VVT can’t be denied. VVT CAM will better compliment a stock stall
Get it in and get it running with Lt's and an after market tune and see what you dyno and run in the 1/4....than decide if you want to loose your technologic advantage with the VVT.
http://www.gmhightechperformance.com.../photo_24.html
http://www.hotrod.com/techarticles/e...s_engines.html
I think most will agree that the tech for VVT is awesome, and does work well on mild builds, but the fact remains that once you start pushing the envelope in search of more power the VVT becomes a hinderance. You CANNOT physically fit a big cam into an engine with VVT and maintain adequate P toV clearence. there is no solid conection from the cam iteslf to rest of the rotating assy, and therefore if P toV is close you are gambling with contact.
Lastly to get the TRUE benfits of VVT(Variable Valve Timing), it would actually have to be variable valve timing, not variable CAM timing, as it really is. If the system allowed independant intake and exhaust phasing then it would really be EFFECTIVE.
When I start buying my cams from you, you can talk about valve events to me.
Barrett
Flame away
For a non extreme build the cam choices and power developed thus far seems like a great choice-while maintaining that wonderful around town pull.
I previously had the 2jzgte engine in a 3k lb car, loved the 320RWHP on 12lbs of boost, loved the 16lb setting also, but I found driving my truck around was more pleasurable. The top end pull of the engine was a blast but down low it was not very fun at all-so now my cars getting an Ls1. My point being-Low end grunt is a blast! and having both is even better.
Does the LY6 use active fuel management (cylinder shutoff)? *EDIT* Answer is no.
I traded my BBC malibu for a very nice Grand national roller yesterday so now i'm starting to collect part for the build. Going to put a came in it for now, but sure if i'm gonna use a mast or comp cam. I'm going to run the Ly6/4L80E combo and get the tune done and have it running so i know what i got. This spring after i save some coin and do more research the motor will come out and get arp fasteners, thicker head gasket and a front mount turbo. There are a few build on here that are pretty nice set ups that i'll be copying. Once i get the parts on sight the build will start and i'll start a thread on it. Thanks for all the input so far
