Has ANYONE ever swapped a 8.1L 496 LS motor into anything???
I just bought one for a great price and going to put new bearings/gaskets in it and do who knows. My father has a gorgous 57 Chevy 2 door that I thought of doing a 5.3 or 6.0 swap into but since I have this motor I love love to use it if possible. So here are the million questions I have:
What LS is this considered if any? Or is this a LQX. I know my truck which is a 6.0 is a LQ9 what is the 8.1L considered?
What transmissions mount to this?
Is the block the same for any other motors? example LS1=LS6
Do you know of any companies that make kits for this motor to swap in for instance mounts, etc...
I know swapping in 5.3, 6.0, LS1, Ls6 are the norm is the 8.1L just a stupid idea or did I pickup a nice motor to work with?
Thanks guys
Thanks guys
I believe the 8.1's are standard BBC design. They are in no way related to the LSx family, and will not interchange any parts. 4L80e will mount to that behemoth, as well as a Turbo 400/350. As far as mounts go, I think you're looking at standard BBC.
8.1's are based on traditional big block chevy, but share electronics with LSx family. 24x crank trigger, 1x cam trigger, coil per cylinder, drive by wire, etc...
Nice thing about the 8100 is all the bolt holes are in the same place as traditional BBC, except all holes are METRIC thread. The 8.1 is a tall deck engine, 10.2 vs 9.8 " deck height, so , head are higher, and outward toward fenders a little more then regular big block. Header patter IS THE SAME, metric holes.
Oil pan is unique, its aluminum, so options for fitment is slim. Mark 5 and Mark 6 oil pans ARE different. The valve cover patter is almost same as traditional BBC, except for one hole on each side. I was able to oval shape the hole in some stamped steel valve covers to make them work. The heads are held on with two additional head bolts, and the pattern is moved around. So 8100 heads WILL NOT go on traditional BBC, or vice verse.
The 8100 is net lash, no adjutment to valve train. However, you can get a stud from ARP with metric threads on bottom, standard on top, and run regular big block chevy adjustable valve train stuff.
Camshaft is roller, you CAN install older Mark V, Mark VI roller cam's. This will change firing order back to 1-8-4-3-6-5-7-2. In stock form, the 8100 shares SAME firing order as LSx family. Programming would need done of course to change injector bank assignment.
I've had two 8100, and both of them suffered piston failures in the end. I've heard they have weak pistons, but I don't know. I know the motor is a torque monster, and I'd love to find another one sometime and build it.
The following users liked this post:
Alabbar (06-10-2024)
These motors are designed for a TON of torque -right off idle. HOWEVER- from what I've read- the rod ratio is low-like 1.40 -since the motor has the 6.135 rods and a BIG stroke of 4.37- and w/ the tall deck, the pistons- I would think- are pretty big and heavy. I don't know if/how/cost of changing to a longer rod- not so much as to reduce friction and the time the piston stays at TDC (or BDC) but to run a lighter piston.
Another thing that concerned me when I was looking at one for my project was the foot/minute piston speed. Using a 4500fpm speed -limits RPMs to less than 6k.
And 'busta9876" sort of confirmed my observations....
PLUS this thing is HEAVY- from what I've read 40-50 lbs MORE than a standard iron Big Block-so you are talking upwards of 720LBS!!!
Richard
Here's a swap in a Corvette-
Richard
It's a 69-
Here's some more pics of the build-
http://mcspeed.homestead.com/Killer-II.html
He (Chris) sold the car (back in Jan) before it was finished.
The guy who bought it- finished and it's in Corvette Enthusiast
June (page 59) and July (page 74) issues
You can view the mag online- after you register-
http://editions.amospublishing.com/K...spx?d=20100901
Then you'll find the issues in "archives"
Richard
Richard
It's a 69-
Richard
Richard
IIRC Chris's user name on this forum is 69myway
I currently have one in my 04 silverado, see avatar. What do you want to know.
Here is a link to my project.
http://www.fullsizechevy.com/showthr...Silverado-SCSB
rod length is 6.700
yes pistons do suck mainly because they have no skirt
the big issue is over revving it with stock valve springs and heavy valves. once they play tag things arent happy anymore just ask busta bigger cam and didnt change the springs. with a big block it is mandatory to change the springs with a cam change. ask me how i know
in stock form with a tune and none of the factory crap 400 hp 500 ft lb motor
I am building another as we speak cnc'ed heads good h beam rods forged pistons and a zz502 cam. should be an easy 500 hp motor
I read somewhere that one or two of the back intake ports are choked bad becasue of different placement of head bolts or something, can you confirm this? I'm assuming that a CNC ported head should take care of some of that problem.
wouldn't want to trade the 8100 for a turn key 5.3 swap would you? ...engine, accessories, modified harness, manifolds, starter etc....
What kind of shape is the 8100 in? what all did you get with it?
my 8100 did at least leave me with some souvenirs....
The motor only has about 43K on it. I am not even going to crack into the heads or the valvecovers for that matter. It had some knock in the lower end and the tech found a couple bad bearings. Were going to go through the bottom, I am going to clean it up allittle and sell it. I dont want a 5.3 but thanks.
the 8100 has everything on top including the coils, egr, and all the fuel system. All pulleys are there. Looks like all thats missing is the starter, alternator, ac pump, and manifolds. In good running order i am hoping to get about $2k out of it.
from what I have read, is that not many are doing swap for High Performance applications due to the fact that there is not a great amount of HP Aftermarket performance parts, cost wise. Due to all of the changes GM made from the Standard BBC's and what not fit's that Busta so well put... High Performance application are a bit dicey.
But for a torque project, it might be ideal. Dress it up with some bing and it will look great in the engine bay !
Harlan did some testing on these motors a while back and got some 650HP out of them with different cam, pistons, intake etc. Heads I think were modified with different parts also. I do like the torque of the motor for sure. Really helps me in my towing.
