how to clean/flush cooling system...
but my cooling system is dirty as heo...was wondering if theres some kind of over the counter detergent i can use to clean it up...i didnt want to waste money just yet and put coolant in there since it was so dirty...
i've ran the motor 5 min at a time with fresh water coming in the radiator and dirty water coming out of the stem tube...did it bout 6 times and still no clearing...
http://www.youtube.com/watch?v=tNSiFYpB_ao
Use what every clean you have.. to me that all work about the same..
for the Prestone Cleaner, you have to drive around with it for like that said 3-6 hours or so, the system has to be running at normal engine temp and pressure for it to clean and lossen the gunk in your system. As far as the Acid contents.. just make sure you flush it well after..
I have used the clean on a few daily driver before.. but will back flush it. .and also run it for a few days with Water, the back flush it a few time.. before adding Anti-freeze/coolant.
And you really want to flush out the Dex-Cool really well. If using old / normal Anti-freeze/coolant. remember, they don't mix with Dex-Cool.. !
dammit...altho my car now drives...overall the car is not in driving form...so i'll do best i can...but it just feels better now that i ran water thru it and no more dookie brown color water is coming out...i'll let the cleaner sit for the rest of the week...start the motor for maybe 3 five minute sessions...
Also i wouldn't worry too much about scrubbing the inside. Just get the water clean, then make sure you get some form of antifreeze in right away. Aluminum doesn't like straight water, and the antifreeze helps lubricate the water pump bushings.
