1969 Chevelle fuel pump in tank?
Iam thinking of buy a tank with a pump in it already...Spectra Premium Part# GM34BFI.....its has..two vent pipes,includes sender assembly with stock-capacity fuel pump 85-115 PSI/50-60GPH;(0-95 OHMS)....any help if this tank would work for the LS1?....Thanks miguel
I have the GM34UFI tank in my LS1 Chevelle and I have had a recurring fuel pick up problem at about 1/4 tank. I have been talking with Spectra about a solution that they acknowledge and are supposedly working on a solution but after two months no resolution. It works fine above that level but the motor starves for fuel in a corner and will die if you don't catch it first.
I am not the only one to have this problem so I wanted you to know before you buy one. I have a single feed LS1 setup and I am thinking about modifying it to a full return line setup that might help alleviate it.
