G-Body CTS-V And John B
First off, the reasons I chose John Bs mounts.
1. John had done a lot of work to position the motor as close to stock as possible ( Center, Height, front to back for weight distribution)
2.This consideration placed the 4L65E tail right where I needed it to use the stock cross member mounting holes and rest on the perch of the stock cross member at the correct height with enough room in the trans tunnel . ( A plus for someone like me that doesn’t want to have to fab a cross member or worry about drive line angles)
3. I was able to use the CTS-V pan kit which I got at a more than reasonable price and it only hangs about 3/4 of an inch below the engine cross member..
For the trans tail housing.. I knew the GTO tail was not going to work so I had to obtain another tail.. I also needed to do something about the stock speedo working so with this in mind I decided to kill two birds with one stone and purchased a kit that retains the reluctor for trans control and adds a provision for a mechanical speedo gear..
http://www.rd-eng.com/pagetwo.html
You can also go the Cable X route if you already have the correct tail for cheaper
http://www.abbott-tach.com/cablex.htm
Below is a picture of the engine bay with John bs mounts..
Engine with CTS-V pan going in..
Engine in...
CTS-V Pan Clearance..
Shots of Stock Xmember in place (notice bolt holes are only a hair off.. All I needed to do is extend the slot slightly in the cross member to fit) also a shot with new tail housing kit installed and comparison to GTO tail..
Thanks John for all your help..
Best regards,
Matt
However, I did have enough room to mount the stock GTO 4L65E trans Dip stick with minimal bending..
It will be fine now but just think of the passenger coil as your distributor in a standard small block when installing (Basically.. What I mean is.. its a good idea to remove it before installing). Mine was on in the photo.. but quickly removed once I saw it was an issue..
Another issue, I must confess, was the orientation of the hoist in the picture I posted. The front approach does not give enough travel to insert the engine far enough...and I had to switch to the side.. (If I would have paid attention to Johns images I would have known this
) Basically.. I didnt snap off another picture after I removed the coil and moved the hoist but keep that in mind if doing the same..
The Alternator was tight as well.. But thats only because the snout of the GTO alternator extends out quite a bit more that others I have seen..
As for the Exhaust.. Theres enough to fit Fbody headers on the driver side with no issues.. The pain is the passenger side..
I will have to make some measurements if your looking for exact numbers..
Matt
Thanks[/QUOTE
I was thinking the same thing.
I have also seen these
http://www.spohn.net/shop/1978-1987-...SX-Swap-Parts/
and I called to get an idea where they place the motor but I missed the return call from thier support guy.. Sorry..
Maybe someone can follow up where I fell short and report back?
Matt
No worries John.. From our previous conversation i knew that you were out of the states quite a bit..
Good to hear from you!
Thanks again!
Best regards,
Matt
Wish Johns mounts were available, i would pick some up for sure.I just picked up a caddy pan for my ly6/4l80E swap into a 87GN.
I've been looking at the BRP mounts it looked like the fit pretty well in Boost-box
GN. I'm not sure if he had issues with the coils hitting the A/C though.
Kinda interested to see how close the caddy pans drain plug comes to the 4L80E flex plate
