2 questions
Old Jul 11, 2010 | 04:48 PM
alitz's Avatar
Default 2 questions
I have two simple questions.
I have two plugs left on my harness, one is for the MAP Sensor and the other is a 5 wire MAF.
1) Do I have to run a MAP Sensor?
2) Is there a way to run a 3 wire MAF?
Thanks
-Ali
Old Jul 11, 2010 | 05:00 PM
tryinggenIII's Avatar
you should run a MAP sensor but it can be deleted with programming. to run the 3 wire MAF you have to add a connection for an IAT (idle air temp) sensor. This is what i know so maybe someone will chime in and correct any misguided info. Good luck!
Old Jul 11, 2010 | 05:01 PM
BlueMagicSS's Avatar
It would help if you say what year, engine, etc... all the pertinent info so someone can help you
Old Jul 11, 2010 | 05:09 PM
The LS1 MAF would work fine, its probably a 3 wire. You still need to run an air temp sensor. The 5 wire MAF plug, 2 of the 5 wires on one side, black and tan are for an air temp sensor. Get the IAT sensor for a 2000 camaro with ls1 or something. Its a two pin sensor.
Old Jul 11, 2010 | 09:48 PM
alitz's Avatar
sorry its a 6.0 out of a 03 sierra
