Need wiring help???
Old Jan 20, 2004 | 08:08 PM
madbrace's Avatar
Default Need wiring help???
I have been having tranny problems lately. When im on the freeway when i let of the gas and lightly get back on it, my trans goes from 2,000 rpm to about 2,500 depending on the speed. But if i keep my foot on the brake gentley breaking the tcc switch it will not do it. Witch brings me to beleive I have wired my tcc switch wrong. Its a 99 pcm, I have pin #33 a purple wire hooked up to a relay that goes to my break switchc its a 85 iroc. The wire pin #33 has 12v constan.when i step on the brake the relay breakes the the current and the wire has no power. This is how I was told to wire the switch. Is this correct, I have been reading other post and it seems every one has theirs hooked up a different way.
Old Jan 21, 2004 | 09:49 AM
madbrace's Avatar
Any ideas, ive read a couple of post that makes it seem the way ive done it is not correct. One post said to use a monte carlo brake switch so that when you step on the brake it sends the tcc wire to ground. But what pcm pin? #33 purple or pin #42 A tan and black wire??
Old Jan 21, 2004 | 10:16 AM
Speartech's Avatar
9 Second Club/LS1TECH Sponsor
It sounds like you have it right. BLUE 33 should have 12 volts on it with your foot OFF of the brake. When you apply the brakes the voltage should drop to 0.
Your RPM change sounds normal too. Under some conditions the computer keeps the TC locked when you let off of the gas, but usually when you let off the TC unlocks, then when you get back on the gas you see the higher RPM. Then right after that you should see the RPM drop again as the TCC re-engages (unless you are giving it a lot of throttle, which would keep it unlocked).
__________________
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
Old Jan 21, 2004 | 10:43 AM
madbrace's Avatar
yeah but the thing is that it will constantly do it if i cruise at a constant speed. It feels as if the trans is in neutral during those rpms, I then get back onit and the rpms go down. Know if i drive with my foot on the break gentley breaking the switch it will not do it. I tried unpluging the purple wire that did not help. Any ideas whats going on. My car has been checked by 3 trans shops , The first one drove it and did not feel anything, the second one told me it might be something electric he said it felt as if the converter was locking and unlocking. The 3rd shop said The trans felt good and that the slipping might be caused by the computer or code p0650, . This is the only code that comes up. I still havent wired my ses light but i doubt thats the problem. Any ideas whats going on ?????????????????
Old Jan 21, 2004 | 01:04 PM
madbrace's Avatar
Can low fuel pressure have something to do with my problem. I just noticed that my pressure is at 50 psi??????
