Malfunction Indicator Light....
Old Aug 7, 2010 | 12:18 PM
LS88FoxBody's Avatar
Default Malfunction Indicator Light....
Looking for the Wiring for MIL Or SES Light for 03 Tahoe. Anyone tell me where I can find the wiring for the check engine light it would be greatly appreciated. I've looked but cant seem to find what I need.
Old Aug 13, 2010 | 05:39 AM
Anyone Anything I wanna get this done tonight...
Old Aug 13, 2010 | 06:04 AM
Alba Gu Brath's Avatar
Could you be more specific ( no sarcasm intended) what do you need as far as "wiring" and what are you trying to accomplish? The reason I ask is , I'd be happy to look on my Mitchel on Demand and pull the wiring diagram for you but I need more info as to the cicuit that it is on because MOD is very picky about little details?
Old Aug 13, 2010 | 06:49 AM
classic79's Avatar
On mine an 02 it is on the black plug from engine harness that went to the body. I think its called like c100 has about 16 or so pinouts on it. Its a brown/white wire. I cut mine and tied it into my swap vehicles cel.
http://www.lt1swap.com/vortec_truck_pinouts/2003.htm
this link has the pinouts for 2003. Its in that c100 plug.
Old Aug 13, 2010 | 06:23 PM
Here are a couple screen shots from the Mitchell Wiring Diagrams... hope it shows up
Old Aug 14, 2010 | 07:50 AM
Well basically I want a standalone MIL . The Motor is in a 92 Mustang. My Harness is Standalone no Intergration really with the car. I see those wires in that harness but I can't figure out where it's tapping into . At the VCM or what?
Old Aug 14, 2010 | 08:04 AM
TomM's Avatar
Second drawing, wire #46 brown. Should be a ground signal to the light, the other side of the light goes to hot. Find that wire in the harness and connect one side to the light, other side to fused hot...if you use an LED, watch your polarity......only works one way...
T,
Old Aug 14, 2010 | 08:11 AM
What I'm saying is in My harness the only things I need is there. All the rest is gone. So Either it would have to be a PCM Pin ,or on the OBD2 Port. Because all my other stuff is used.
Old Aug 14, 2010 | 10:57 AM
classic79's Avatar
You should have a green connector on your computer and the brown/white wire is in pin 46. Thats the mil grounding wire for you light.
Old Aug 14, 2010 | 03:46 PM
TomM's Avatar
Then you are going to have to add the pin and wire to the PCM connector. Get one from a used harness, color doesn't really matter, as long as you know what it goes to....
T,
