How to get codes from check engine light
Old Aug 11, 2010 | 10:58 AM
classic79's Avatar
Default How to get codes from check engine light
Engine 2002 4.8 out of a silverado into a 89 burb 2wd with 700r4.
Is there a way to pull off any codes from the computer without a scan tool? I could pull them up before using a jumper wire and counting the CEL lights flashes with the old computer. Can I do it with the new puter setup?
Hooked up the CEL and it is coming on. That and it idles high now that I put a mass air meter on. Before I put the mass air on it idle fine. Of course now the computer is hooked on the mass air like meth and won't run without it hooked up.
I already tripled checked for vacumn leaks, found one cracked hose fixed it, but still same problem of high idle.
Anyhelp would be mucho appreciated!!
thanks
chris
Old Aug 11, 2010 | 11:33 AM
eastcoastbumps's Avatar
Chris, you'll need to get your OBDII port working. You can get a flying lead off a car in the junkyard or buy a new one. Its a 4 wire hook up. Constant 12V, engine ground, chassis ground and data from the ECU.
Pete
Old Aug 11, 2010 | 03:30 PM
nissan 570sx's Avatar
Right in one of the sticky threads up top.
Old Aug 11, 2010 | 08:04 PM
classic79's Avatar
but even with the obdII port do I need to buy a code reader? or is there a way to pull the codes like obdI did.
Old Aug 11, 2010 | 08:55 PM
You can just swing in to Autozone or the like and have them pull the code for you if you don't have access to a scan tool.
Old Aug 12, 2010 | 07:00 AM
Pop N Wood's Avatar
I think they got rid of the blinking CEL light like some of the OBDI systems use to have. A code reader is much nicer than counting flashes anyway.
Harbor Freight use to sell a code reader for $30. I have one and it works great. Notice the cheapest one they have now is on sale for $50. Looks like it does a little more than the one I have, although don't know why being multilingual would be desireable. all I want is the number codes.
http://www.harborfreight.com/can-obd...enu-98568.html
+1 on the autozone idea
Old Aug 12, 2010 | 08:54 AM
classic79's Avatar
I think I will see if I can find one at Harbor freight local then. Thats a good reason to buy another tool.
One a positive note I fixed my high idle, the throttle cable I used was off a 96-98 vortec tahoe and as just a little tight in the throttle bracket. Elongated the holes to move the bracket just a hair and now it idles normal again. Yeah for cheap fixes!
Old Aug 12, 2010 | 09:59 AM
claytonisbob's Avatar
Has anyone got one of the ODBII w/ CAN scanner off of fleaBay?
http://cgi.ebay.com/ebaymotors/ODB-2...motiveQ5fTools
It would be a cool device to have if it in fact read the o2 sensors ect.
