LS swap into a 67 Camaro help!
You need headers and motormount adapter plates that are designed to work together - the adapter plates can change the fore-aft mounting point of the engine, which in turn affects header to steering box clearance.
An F-body oil pan will (I think) work with adapter plates that move the engine the farthest to the rear - look at the Pertronix SK100 plates for use with Dougs D3337 headers.
The GMPP front accessory kits w/o AC are a good economical setup, with the Kwik brackets for the compressor if you're using AC.
You can adapt a factory style radiator (passenger side inlet/driver's side outlet) with careful hose selection, or buy a purpose built radiator.
You'll likely need to fabricate your own cross member, depending on transmission selected.
I'm not aware of anyone who does a wiring harness to hook the LSx engine harness into the first gen F-body wiring, but then it's only a 4 wire hookup so that's not really an issue.
In addition to this site, there are a lot of threads on Pro-touring.com, Lateral-g.net and Camaros.com detailing LSx into first gen F-body swaps.
Anyway, first decide which engine it is going to be and start from there. Good luck, should be fun
https://ls1tech.com/forums/conversio...68-camaro.html
