1st gen mustang: build thread!
1) i need to sell my old ****... as such, this was created to help with fundage... Being that im not doing this with any real illusions of grandeur, heres some info for any other potentially heretical 1st gen/ls guys out there:
http://www.corner-carvers.com/forums...t=39639&page=8
2), I got this home :
sitting there, waiting for room for testfitting..
Still undecided on the method of induction (fast ez efi, truck intake, edelbrock), but im thinking a 347 is plenty..
The more i look into it the more im thinking ill go auto on this build; so much for getting the t5 off of principle
researching paddleshifters as well as shifter-options (ie not factory/lokar/b&m) Last edited by Irish350; Jan 3, 2011 at 06:24 PM.
SWS
but after some consideration im thinking i may go mustang II as well, after some practice..
well see
Since i havent really been stressed out by finances lately, i decided to not only plunge into my unsuspecting credit, but also to put more pressure on myself to get rid of stuff that would otherwise work perfectly fine!!
I had planned on going with GM heads to keep the budget from getting out of hand on this (compared to my TA which is still actually going up as i type this..). While perusing the classifieds here i came upon a set of brand new 243 castings (ls6 heads, on the streets) that had been worked over by a guy named Chris Frank, at Frankenstein Racing Heads. The seller, a guy named Ben, also grabbed a billet cam thats spec'd for daily driving use, while still taking advantage of the lungs these heads have. Im not gonna say Im even in the top 50% as far as head/cam knowledge goes on these forums, but i was really impressed by these numbers after doing some research.. What didnt need any reading up on, was the PRC springs good to .660", REV valves, and the titanium hardware. They were also milled .03"
Valve Lift / Intake cfm / Exhaust cfm
0.200 144 112
0.300 205 170
0.400 264 203
0.500 294 224
0.550 310 228
0.600 318 233
Nothin too crazy for the cam; I think its a bit more duration and a bit less lift than my old cam, which is in the block (and will be coming out). Supposed to be good for 460whp through a 6 speed.. Im glad its billet after seeing the current cam after 40k
235/240 .595/.595 on a 110LSA
This stuffs not getting anywhere near the shortblock until after its back from the shop.. Its still sitting just like it was when i updated. Once the funds are replenished from this stuff ill be getting it torn down, assessed and rebuild. This is already going totally overboard, the engine used to make 430 whp in my trans am with the AFR 205s it had, and these heads flow better and the car will weigh less...
Now that ive shown some thigh, whos got suggestions as far as a trans/rear end?
Im thinking 4l60e vs TKO600 or something, but for one, i dont know anything about smaller manuals, and two, i cant even decide on manual vs auto, haha.. Since itll be my daily im thinking an auto would be smart, but everythings a compromise.
So i thought id see if anyone had any thoughts on this.. Right now im trying to decide between (amongst other things) intake/control systems..
OPTION ONE:
-Truck intake-
Thinking TBSS intake, factory PCM, injectors, tb, rails, etc. This would mean I could use DBW and a 90mm tb. I think this would be less expensive, and more of a hassle
Pic stolen from carfreak07, id certainly copy him and shave it up (his cool monte)
OPTION TWO:
-Carbie EFI-
I think more power, more money, better looks, and less of a hassle tuning, wiring, etc. would be to run a FAST EZ EFI, along with a carb style Victor Jr/Super Vic.. Going this way means a 'cobra' style Edelbrock filter, which will REALLY make the ford guys "
It seems like the truck setup would be great under the curve with this setup (especially if portmatched to the heads), but would probably run out of steam before the rest of the engine. The 4150 style intake would certainly allow it to breathe better, and the FAST setup is as inclusive as a full truck-system pull (tb, injectors, computer, rails, etc), its more expensive off the bat but would keep from needing a tune and some of the wiring shtuff..
What would you do?
Jack.
Jack.
I feel like Ive got the best tuner in the Southwest at my disposal, assuming Ive got to get it tuned. That said, if i can save from having to tune it - say if this FAST software is 'smart' enough, itd be nice.. Unfortunately I havent found a TON of info about this setup yet. I think the key is going to be the cost difference between the two, and whether or not the power/looks is worth it.
Been thinking about the intake more than anything else, but i did realize that if i wanted, i could make this a 5.0 ls1 (with a 4.8 crank)... kinda cool. probably wont, haha. plenty of time to think about that before the block gets rebuilt
I also took a minute to dust it off, i felt neglectful. I also did as i do about once a month; popped it opened, took a look at how nice the interior is (even only partially done) and sighed at how bad i need to drive this thing.
Also, i noticed ive been accumulating a decent amount of f-body accessories, so i wanna see if thats an option for accessories on this, or if a GTO setup will give the most room (sure would like to have PS/AC...)
Only excuse now is time and money, but i do have some more motivation lately, and after getting my ta back ill have a car thats 1)fun 2)a gas guzzler, so this will be back on.
(also dont bring up the fact that im trying to pass this off as a viable mpg car)
could use either one, or sell both for one thats spec'd both to the car and the engine (wp outlets).. anyone?
do the mavs have more strut clearance? (or are they bigger than falcons/stangs?) What accessories did you go with? oil pan?
