converting r-12 to 134
Unless your vehicle has rear air or 2 seperate evaperators in the front, it should only have one orifice, since the orifice is used to seperate the high side of the system from the low and converts the higher pressure liquid to a lower pressure vapor. Since you can only do this once , there would be no need or purpose for a second orifice, unless there are parellel evaporators in the sustem, each with their own orifice.
You might be thinking of the little inline filters that some systems use.
To the OP, if switching to 134 you will also need to change the O-ring seals, since the R12 ones will not last long being exposed to the oil used with 134
