E39 BMW 540 LS Swap Completed
Old May 24, 2011 | 01:21 AM
  #81
Euphoric's Avatar
those numbers are amazing! what a sleeper. excellent swap.
Old Jun 7, 2011 | 02:17 PM
  #82
rao's Avatar
rao
Did some logging today (this is the first real time the temps have been hot since I installed the supercharger setup) . Ambient temps of 95+ with high humidity (not that it matters to the car), cruising intake air temps were in the 120s and coolant temps stable in the 200-210 range (which is under where the fans come on), so the intercooler is adequate and all in all it is good news. All of this was with the AC on
Old Jun 7, 2011 | 07:04 PM
  #83
merim123's Avatar
that is impressive, especially in today's nasty heat
Old Jun 9, 2011 | 01:28 PM
  #84
AmericanMuscle313's Avatar
Will you elaborate on how you got the A/C system to work? Did you end up using the bmw a/c compressor or GM unit in the stock location?
Old Jun 9, 2011 | 03:05 PM
  #85
rao's Avatar
rao
F-Body compressor in the stock location run by the GM computer.
Old Jun 12, 2011 | 10:16 PM
  #86
mujjuman's Avatar
wow!!! i want someone to do this to my BMW!!! minus the S/C
just the swap would be cool!!!
Old Jun 13, 2011 | 05:48 PM
  #87
bikealarmblair's Avatar
I'd like to know more about how you have got the tacho & coolant guages to work, I know you have said a few times the cluster needs to be recoded but how?
Does the PCM you are using have can bus or have you managed to conect conventional outputs to the cluster??
I'm outting an 04 LS1 into an E46 325ci & would really like to sort the guages
Blair
Old Oct 26, 2011 | 01:02 AM
  #88
One Bad Duramax's Avatar
Originally Posted by rao
The instrument panel is fixed, the CAN BUS finally gave up its secrets
Pardon the video quality:
could you pm what wires you used to connect the coolant rpm and MPH
going to start an e31 bmw ls build soon
Old Nov 22, 2011 | 08:56 PM
  #89
jakeb's Avatar
Excellent swap...I am about to start an e28 swap.
Old Jan 1, 2012 | 01:58 PM
  #90
barkerpa3466's Avatar
Hey rao
Nice build
I am thinking of doing the same swap (starting a family and I don't want the standard baby hauler.)
Anyway I was wondering if you have any pictures of the engine and tranny mounts in and out of the car.
Thanks
Old Apr 7, 2012 | 08:18 AM
  #91
Thumper28's Avatar
I'm sorry if I missed this in the thread but have you taken it out to the track yet? Any 1/4 mile times to share?
Old Sep 29, 2012 | 05:51 PM
  #92
rao's Avatar
rao
The car keeps rolling along with some maintenance but nothing major.
I took it to LS Fest in Bowling Green and received this nice surprise in the mail today:
Old Sep 30, 2012 | 06:55 PM
  #93
mikezohsix's Avatar
Having done a unique swap myself, I know how important it can be to have someone recognize the engineering as well as the blood and sweat that goes into a swap like this. Congradulations!
Old Oct 15, 2012 | 04:10 PM
  #94
rao's Avatar
rao
I changed my intake set-up. I went to a 102 mm throttle body and a 4" intake tube, up from a 90mm and a 3.25" or so intake tube (the original Magnacharger plastic tube gets pretty narrow). People told me it was too restrictive for a 402 setup running 11 psi of boost and I have to say they are correct The change in throttle response is pretty material. I still have to finish cleaning up the tune, but all in all it was a great move. It was worth the time and effort.
Old Dec 14, 2012 | 06:05 PM
  #95
Tjabo's Avatar
Beautiful project Rob, it's appropriate that you were awarded for your efforts with this!
Have you given any thought to whether the truck intake and accessories would fit under the stock 540i hood?
Do you think the A/C control might be easier to tackle on a '97? I've heard that up through June, '97 (or somewhere around there) they have less reliance on the CAN bus......?
Also, regarding your aborted plans for a turbo setup, did you give any thought to a front mount system that would allow for gravity drain, or was it apparent that it would be really difficult to fit all of the plumbing?
Thanks in advance for anything you can comment on!
Old Dec 14, 2012 | 06:53 PM
  #96
rao's Avatar
rao
I am not sure if a truck intake would fit. The problem is going to be at the throttle body, there is plenty of space at the firewall end.
It turns out that the model year will make no difference for the AC or instrument cluster.
You could fit the plumbing for a top mount turbo, I decided I didn't want to go that route.
Old Dec 14, 2012 | 07:06 PM
  #97
Tjabo's Avatar
Thanks Rob!
I take it then that if the throttle body would clear the hood that you would expect the other accessories to also fit okay? I guess in addition to the alternator sitting up high the accessories all sit out another inch or so to the front.
I kind of like the idea of having the alternator up there where you probably wouldn't run turbo setup plumbing, so if it all fit under the hood that might be a nice deal. Do you think the reduced clearance to the front would cause any big problems?
Old Dec 14, 2012 | 07:11 PM
  #98
rao's Avatar
rao
I'm not familiar enough with the truck accessories to know for sure.
Old Dec 16, 2012 | 01:03 AM
  #99
mapleridge's Avatar
wow. amazing. BMW + LS power. So perfect. My dream for my E90.
Old Feb 5, 2013 | 08:05 AM
  #100
rao's Avatar
rao
A little update since it has been a while.
Well my plan has worked. I figured that having three full sets of wheels with snow tires would keep the snow away and it has worked We have had plenty of cold temps but not a lot of snow.
This is the most snow we have seen this season so far:
I also installed a set of 60 lb injectors, my new air intake system took me past the limits of my ls9 inectectors
