E39 BMW 540 LS Swap Completed
Old Dec 23, 2014 | 12:59 PM
  #141
rao's Avatar
rao
Next on my list was to redo the front of the exhaust. There was nothing wrong with what I had but I wanted something larger, easier to service and to move the o2 sensors closer to the exhaust ports.
In this thread https://ls1tech.com/forums/conversio...have-seen.html I looked at the then newer 2nd gen CTS-v manifolds, but they didn't fit in my car the way I wanted. The Hooker manifolds were brand new at the time.
I went with Hooker LS Exhaust manifolds. They still aren't as large as what a lot of people use, but they are much larger than the 98 Camaro manifolds that I was using. They are very high quality and fit as close to the block and swept back as anything I have ever seen. I was able to get the front o2 sensors much closer to the exhaust ports. Also they will be much easier to service than what I had.
Now the exhaust has been totally redone. I have to clean up the tune; I’m not expecting a huge gain, but you never know 
I didn’t take a lot of pics, was too busy rolling around on the garage floor trying to put this puzzle together.
Holley Hooker 8501 exhaust manifolds (I ground the logos off)
Passenger side downpipe (sorry, didn’t get a pic of the driver side)
These are very tight to the block, here they are installed:
Driver’s side manifold
Passenger side manifold
Old Dec 27, 2014 | 05:24 PM
  #142
rao's Avatar
rao
More fun in the garage
When I did the tuning from my new supercharger and manifolds I noticed that I was running out of fuel pump not a big surprise and it verifies that the car is making more power, as it should since it is making more boost. I should have plenty of injector but we’ll see.
Originally when I set up my car I was using a “returnless” fuel system with a Corvette style filter/regulator. It isn’t really returnless since there is a pressure regulator and the fuel is returned to the tank, but it does run at a constant pressure, in my case 58 psi. This means that at idle the injector is infecting into a vacuum so the output is “enhanced” and at boost it is injecting into 15 psi. This can cause problems at higher boost levels and can lead to uneven rail pressure. This system is very simple and works quite well; now that I am up around 15 psi of boost a vacuum referenced system should do the job better and provide for more capacity from the pump.
A return style system has a constant pressure differential between the injector and the intake manifold, which so that at idle the pressure is reduced so that the differential is 50 psi and under boost the pressure is raised to 65 so that the differential is still 50.
Fortunately, GM made both types of systems (the LS based trucks use both) so Magnacharger did as well. I had the return style fuel block so all it took was a quick swap and a change of the fuel filter and some plumbing.
The filter is one used by GM on literally millions of cars so every auto parts store has them on the shelf and it has plenty of capacity.
Here are some pics:
Original Fuel Block
Original Corvette Fuel Filter/Regulator
New Fuel Block
New Fuel Filter
I did some quick tuning and it seems to be working fine. Once I get the new 340lph pump in place I can really test it
Old Dec 27, 2014 | 05:41 PM
  #143
Project GatTagO's Avatar
Rob,
Is that new rule block integrated into a new rail?
Andrew
Old Dec 28, 2014 | 07:00 AM
  #144
rao's Avatar
rao
Rob,
Andrew
I think you mean fuel block. The fuel blocks bolt to the fuel rail so they are interchangeable.
Old Mar 8, 2015 | 04:55 PM
  #145
rao's Avatar
rao
After I switched the supercharger head unit I had a couple of minor clearance issues, all of which were easy to fix. The one that I couldn't fix was the position of the throttle body coupling about 4.5 inches out from the throttle body - which was about as short as I could make the coupling.
I needed to angle down the throttle body just a little with a wedge, but I also needed the wedge to be fairly small so it didn't mess up everything else.
I saw the Vararam "Power Wedge" which is about the last product I would buy, but looked like it might do the trick and would be easier than making something from scratch. I ordered one from Summit racing.
It turns out that the angle of the wedge is around 5.5 degrees; I needed to know how much room this would move the tube down about 4.5 inches from the throttle body. After spending 5 minutes reliving high school trigonometry trying to calculate the change I decided that it would be easier to just draw it up to see how much clearance I would gain. I needed 1/8" it looked like I was going to get 1/4"
Since it looked like it was going to work I then hogged out the inside to match my 102mm throttle body and installed it. Success! It gave me plenty of clearance. I did have to massage the bottom of the throttle body which was now hitting the fuel line, but after a few minutes it was done.
Final result:
Old Mar 8, 2015 | 07:55 PM
  #146
jmilz28's Avatar
Great work and ongoing follow up. This has to be one of the best swaps out there!
Old Mar 11, 2015 | 02:37 PM
  #147
rao's Avatar
rao
Thanks
Old Apr 19, 2015 | 10:36 PM
  #148
Fweasel's Avatar
I recognize that garage floor. Now that I own a proper LS, maybe I'll stop by for some upgrades. That is, once I figure out what type of German grade Castrol I should be running...
Old Apr 20, 2015 | 05:13 AM
  #149
rao's Avatar
rao
Glad you finally got one. That oil search could take some time
Old Jun 27, 2015 | 05:36 PM
  #150
rao's Avatar
rao
Got fed up with the Dynomax VT muffler so I found a nice new stock muffler and all is well
In other news, my car is up for sale
https://ls1tech.com/forums/vehicle-c...-25-000-a.html
Get it while you can
Old Jun 29, 2015 | 06:46 AM
  #151
Rob,
I should come and visit with my Cougar and check out the BMW.
Andrew
Old Oct 10, 2015 | 08:05 PM
  #152
rao's Avatar
rao
The car is now being parted out:
https://ls1tech.com/forums/parts-cla...l#post18996881
Old Oct 18, 2015 | 02:37 PM
  #153
rao's Avatar
rao
The time has come my e39 swap is no more. Economics dictated that the car had much less value as a running car than as a pile of parts, so parts it is:
It has been a great ride, literally. 5 years and over 100,000 miles of fun.
I will be posting the parts that I kept so stay tuned for detailed posts in the classified forum.
Otherwise I will be out of the swap world for the time being.
Everybody have fun
Old Oct 18, 2015 | 02:58 PM
  #154
BrownMK3Kid's Avatar
well thats not the way i saw this going lol
Old Oct 19, 2015 | 10:58 AM
  #155
drmrman's Avatar
that escalated quickly.......
Old Feb 3, 2017 | 03:45 PM
  #156
Twan0520's Avatar
Originally Posted by rao
Thanks. for the CAN/BUS you have to be able to code the instrument cluster module.
Fitment issues - just order up E39 swap mount kit from Summit Racing and it bolts right in The trickiest thing is the exhaust. What you really need is something that keeps everything tight to the block and up at the heads and goes pretty much straight back.
I had the AC working about 6 weeks ago
It gained 26 lbs, but that was comparing a full gas tank to an empty one, so it probably lost 40-50 lbs.
No badging for me - in fact I debadged it
01 F-Body harness, computer and accessories.
Pics from last weekend:
By any chance do you remember what kit you used for you E39 swap from summit racing? When I contacted them they said they didn't sell those.
Old Feb 3, 2017 | 05:02 PM
  #157
Tjabo's Avatar
Sorry, but I'm pretty positive that was a joke.
Old Feb 3, 2017 | 08:28 PM
  #158
truckdoug's Avatar
lol that last 2 pics.
Old Jun 5, 2020 | 02:56 PM
  #159
Joshua Ralphs's Avatar
Default e39 Swap
Hey there!
I am looking at doing the same with a 5.3.
Can I maybe get your email and we can talk about some of the details,
Thanks,
Josh
