Hooker versus Edelbrock LS Conversion Header Kits Camaro
First off this is my first post and I must say I've REALLY gained a ton of information from this site for my FIRST LS conversion, Very helpful/friendly people here
Now... I've been searching for good pictures of both edelbrock and hooker kits installed in a first gen camaro, so far I've only seen the hooker set up, not much about the edelbrock set up. I'm debating between the Hooker LS Conversion headers/motor mount plates and the Edelbrock system. The good and bad are listed below.
Hooker:
Good - from what I read good clearance all around, move engine close to firewall, can get away with using stock oil pan.
Bad - not stainless steel, not step up tubes, ceramic coated, cost slightly more than the Edelbrock kit.
Edelbrock:
Good - good clearance with their motor mount plates, stainless steel, entire exhaust kit cost $1250.00 (if I chose to go that route).
Bad - May not work with stock oil pan, acessories may not clear, spoke with tech and they said I can use CTS V pan or Autokraft (there goes the cost savings of the edelbrock kit
Anyway, if ANYONE has any experience with either kit in their first gen camaro, please advise and SHARE PICS if possible. So far I'm leaning towards the hooker set up because I've heard a lot of good things from members here and at other sites. However, it would be great to see more pics from the edelbrock set up.
Thanks...
Here's one other. I converted from the small block heater core & cover to a big block heater core & cover. The tubes from the small block cover in conjunction with the thickness of the heater hose rubber will not allow enough clearance from behind the pass head. The tubes on the BB cover exit in the middle of the cover, giving plenty of clearance.
The heater core & cover also qualify for that 20% off sale.
Are the oxygen sensor bosses already welded in? Do they aim a good direction?
What is the outlet size after the collect & ball/socket setup? 2-1/2, 3, or ?
O2 distance from the heat source has been noted as a possible cause of erroneous O2 operation in closed loop. I haven't fired my engine up yet, so I can't speak from first-hand experience. Maybe someone who has already run Hookers can chime in......
If the Edelbrocks have O2 bungs welded into the collector itself, or into one of the exhaust tubes, the O2's might operate more dependably.
Mister D...thanks for reaquanting me with my original thoughts. Time goes by and I've forgotten some of the finer points to the debate!
No, the O2 bosses are not welded in. I did't want to screw up the coating so I put them right after the collector.
I want to say 3 in for the outlet size. I am running 3 inch exhaust all the way back on my camaro
Your help with my project has been wonderful! The tips and details I have gathered from this website is amazing! Great to hear about everyone's experiences. One day I'll be sharing mine
