air filter dimensions
Old Sep 17, 2010 | 07:50 PM
leon phelps's Avatar
Default air filter dimensions
Hello,
Doing a LS1 into a 65 impala swap.
I am curious what the dimensions of the 90 degree air filters are.
I am almost ready to make the final welds for my radiator brackets and wanted to be sure I can fit some sort of air filter in there.
Thanks for any leads for info.
Old Sep 17, 2010 | 10:46 PM
bczee's Avatar
What are you referring to as "90 degree air filters" ?
Are you talking about the 3 1/2" to 4" tubing used to route air into the Throttle Body/MAF (many use a cone air filter) ?
If your tight for space, S&P makes a MAF/Filter, check there Catalog.
Old Sep 18, 2010 | 01:49 PM
yep I was talking about that.
I saw the S&P one. $175 plus freight seems a little steep for an air filter setup.
I have seen some people use a 90 degree elbow, then some black PVC to the air filter. They use the MAF in it too.
Old Sep 18, 2010 | 04:36 PM
This is that I have to deal with.
Thinking something like this product....
http://intakehoses.com/Merchant2/mer...gory_Code=9DEH
Old Sep 19, 2010 | 01:37 AM
bczee's Avatar
I got my elbows from Jags that Runs.. http://www.jagsthatrun.com/Pages/Par...n_Ducting.html
There are many others online..
