Need help with LS1 swap that is running to hot
I am running at 200*F – 225*F
Here is what I have done so far
Replaced the thermostat
Replaced the radiator cap
I tried to get the block to burp by filling through the coolant temperature sensor, rocking the car and slightly revving the engine with the cap off.
Is it possible that the block still has not burped?
I am running the factory 1985 fans. They are both coming on at 180*F.
Is it possible that these fans are undersized? I have been following this build http://mcspeed.homestead.com/LSXC4.html the only difference is that I used a larger cam, CNC ported 243 heads and that’s about it. In this build they used the factory fans.
Any help would be great, thanks Mark
