Drive by wire pedal pictures?
Old Oct 1, 2010 | 06:04 AM
oldgoat69's Avatar
Default Drive by wire pedal pictures?
I am just about ready to start setting up the throttle pedal assembly. The car is a 1969 GTO, engine is LQ9 with magnacharger and DBW throttle body. What have others done? I want to maintain the DBW. Pictures, part numbers? All help is greatly appreciated.
Old Oct 1, 2010 | 07:07 AM
garys 68's Avatar
What year LQ9?
Old Oct 2, 2010 | 05:07 AM
oldgoat69's Avatar
The engine is a 2004, the trans is a 2003 4L60E.
Old Oct 2, 2010 | 09:44 AM
philntx's Avatar
2003 LQ9, Stage 3 CNC heads, Blower cam, '05 90mm Vette DBW throttle body, 2004 Truck PCM, Dr. X adapter, 05 TAC module and pedal, (not in this picture, 8-rib pulleys), '03 Escalade 4L65E (modified), Autotrac 4WD, NP246 Transfer case.
Modified gas pedal with 05 Vette DBW electronics
Blower snout with the 4-bolt pattern for the 90mm TB
Old Oct 3, 2010 | 09:51 AM
oldgoat69's Avatar
This is where I am so far.
I have a 2004 truck PCM and complete wiring harness. The next phase is pinning out the harness(can't wait for that adventure). The engine and supercharger were purchased as a complete assembled package out of a wreck with all of the electronics.
Which pedal/tac and harness will work with the truck TB?
It looks like the entire pedal assembly you have fabbed is about 12-13" long, is that about correct?
Attached Thumbnails Drive by wire pedal pictures?-001-copy.jpg   Drive by wire pedal pictures?-002-copy.jpg   Drive by wire pedal pictures?-003-copy.jpg
Old Oct 3, 2010 | 10:33 AM
garys 68's Avatar
Your best bet is to go to Rock Auto website and look up the parts for the vehicle the engine/computer came from. If you click on the p/n, it will tell you wahat vehicles the APPS, TAC, TB, etc will work on.
The TAC/pedal harness was part of the dash harness on my 02 Escalade LQ9, so no way to separate it. I bought an aftermarket one.
Old Oct 4, 2010 | 05:35 AM
oldgoat69's Avatar
Where did you get the harness?
Old Oct 4, 2010 | 07:48 AM
garys 68's Avatar
Try Speartech.
Old Oct 5, 2010 | 05:54 AM
oldgoat69's Avatar
I will give them a look.
Old Oct 24, 2010 | 07:44 AM
mwfrels's Avatar
philntx: Can I squeeze a question into this thread that will help me with my swap. I need to install a '03 Vette DBW pedal in my thirdgen Camaro and it will have to be modified to get it to mount on the firewall due to this large bulge for the windshield wiper motor. I am going to have to cut and weld the pedal arm also. Before I break out the security torx drivers to dismount the electronic module could you give me any insight on how it connects to the pedal pivot shaft and any gotchas I might run into? Any info will be appreciated.
Mike
Old Feb 12, 2013 | 07:40 PM
HRD's Avatar
HRD
Here's a shot of a 55 Chevy convertible we did for a customer with a GTO DBW pedal that we adapted a Billet Specialties pad to the arm. It wasn't very difficult.
Old Feb 17, 2013 | 01:57 PM
KTOWN's Avatar
I know this is an old post. Philntx did you cut the center out of the vette pedal and use the outer edges of the pedal to weld to a flat piece of metal. How thick of metal did you use?
