1990 Nissan 300zx, What should I do?
I recently aquirred a 90 300zx n/a automatic. Has anyone on here done a similar swap? I searched but found very little.
u know how to weld??? u know someone who know how to weld??? are u mechanically incline??? if so pull the motor and tranny...cut the firewall/tunnel...and refab...lsx with fbody/autokraft oil pan will work...build ur motor mount and tranny mount...now u r done...
It's been done...I've seen it, more than once. I just can't remember which forum I saw it on.
Looks like I got ahold of a free 94 n/a motor, im just going to swap it in and trade the car for a small truck so I can focus more on the camaro. Thanks for the input though!
I'm in the middle of a 1990 300zx tt transformation. The TT is out and an iron block LQ9 with LS3 heads and intake is going in. Better yet, it's going to be a single turbo(78 mm). This is a tough swap to do, but if you have a good plan, it's not too bad. I'm doing it without cutting up the tunnel, and keeping the AC.
