Possible Alternator Problem??
Old Oct 10, 2010 | 11:10 AM
gMAG's Avatar
Default Possible Alternator Problem??
...While disconnecting the wire from the output pole of the LS1 alternator, I turned the pole instead of the nut holding down the wire. There isn't room to hold the inner nut so I took the chance that it would come off...and it didn't.
So, after doing the correct thing and removing the alternator, I was able to disc it properly. Did I damage any internals/break any wires. The nut prob was turned twice before I realized my mistake.
After removing the nut, it appears that the pole only screws in, but I don't know.
Thanks.
Old Oct 10, 2010 | 06:50 PM
gMAG's Avatar
It appears that the pole in question screws directly into a metal plate and is not connected in any other way.
Old Oct 10, 2010 | 08:28 PM
98silvertacrbn's Avatar
yeah your fine that stud just screws in
