What PCM are you running?
Old 10-12-2010, 11:24 PM
hdkarmy's Avatar
Default What PCM are you running?
I'm doing an LQ9 in a 73 nova. It has an ms4 cam (push rods springs), BBk intake and a T-56. It's time to look for a computer. I think I would like to run the drive by wire. Is the Lq9 pcm ok for this set up? Has any one run in to any problems running this computer? What do you all think.
Old 10-12-2010, 11:44 PM
Chevy406's Avatar
If you decide to go with drive-by-wire, then it makes sense to start with an ECM from a DBW vehicle. It is not totally necessary however. You can take an F-body ECM and re-write the program from a DBW vehicle. What you do need to make sure is that your crank reluctor wheel and ECM match (i.e. 24x or 58x).
