Which wire for speedo from computer???
Old Oct 20, 2010 | 03:53 PM
popeye's Avatar
Default Which wire for speedo from computer???
Have a 2003 Yukon 5.3/4L60E, stock wiring harness. Using the Dakota Digital SGI-5 interface to a Haneline speedo.
On the PCM Green connector
PIN# 20 Lt Green/ Blk VSS low
PIN#21 PPL/White VSS High
PIN# 49 Yellow/Black Vehicle speed signal
PIN#50 Dk Green/White Vehicle speed signal
I currently have the PIN#50 hooked to the SGI-5 input, the green light is on but nothing else. Instructions says no VSS signal to the unit. Dakota Digital was no help.
Old Oct 20, 2010 | 04:15 PM
Clyde65's Avatar
does it say it wants a syn (sp?)wave ( from VSS) or pulse? ( from PCM)
Old Oct 20, 2010 | 06:16 PM
popeye's Avatar
Pretty sure its pulse.
This is from the instructions.
Early Ford Transmissions - the pulse signal generator will thread directly to 32-48 torgue tube type enclosed drive lines.
Computer Transmissions - signal obtained from computer systems. Refer to factory diagrams.
GM Computer Controlled Transmissions - Late 700R4, 4L60E, 4L80E consult factory manual or a wiring harness manufacturer for a location of signal source. A signal translator is required.
