Inline fuel pump location.
It is just note recommened.. read the instruction that came with the pump.
Seem to me, same issue with either a High (EFI rate) PSI or a Low PSI pump would still have the same issues if being mounted above the tank. Let not get away from the original question.
So yes you can mount it higher but not recommended, prolly causing premature pump failure as bczee stated earlier.
