Another ls1 Fox
Old Jul 29, 2011 | 10:08 PM
  #81
brianw401's Avatar
Just think how quick it would be with a set of AFR, TFS heads & a ported fast. Easy
60 -70rwhp more depending on compression. I had a 437rwhp. 331 stroker n/a 93 lx & I was running mid 10's with it because it only weighed 2,780lb. & the suspension geometry on fox stangs is killer. With 4:30 gears & slicks, your car will pull the front tires. Awesome build. Keep us posted!
Old Nov 17, 2011 | 09:12 PM
  #82
tex1978's Avatar
Just read all this, nice build. Any updates? Was wondering if you were having any water pump belt slippage at all?
Old Jan 7, 2012 | 09:51 PM
  #83
ebk06's Avatar
Man I havent visited this thread in a long while lol. I havent had any issues with the belt slipping. My only issue is the starter gets heat soaked. I need to find a heat shield to install.
Old Jan 10, 2012 | 10:03 PM
  #84
bad6as's Avatar
by chance do you have any more pictures of the way the alternator bolts to the block? is that the stock fbody bracket?
Old Jan 11, 2012 | 02:12 PM
  #85
all juiced up's Avatar
ebk06: do you think that the 6an fuel line is enough
Old Jan 23, 2012 | 08:58 PM
  #86
zmonsterjb's Avatar
subbed
Old Feb 11, 2012 | 07:28 PM
  #87
ebk06's Avatar
There wasnt anything special about the way the alt was mounted. Stock configuration worked perfect. The 6an line for my application is more than enough. You will need to figure out your goals and go with the correct size line for your car.
Old Feb 12, 2012 | 03:22 AM
  #88
RATBOX's Avatar
It'll easily support 600whp.
Old Feb 24, 2012 | 10:19 AM
  #89
did you have to use the stock neutral safety wires from the mustang to get the car to start or can you elimnate them
Old Feb 24, 2012 | 11:32 AM
  #90
bjamick's Avatar
You do not "have" to have the NSS. You can bypass it and go straight to the starter. Which is prob what I will do.
Old Feb 25, 2012 | 11:25 PM
  #91
caviness's Avatar
Nice....
Old Feb 26, 2012 | 01:34 AM
  #92
c-ham's Avatar
i would love to see even cell phone vids!!! sound clips with exhaust on it etc. maybe a fly by in a quiet neighbor hood of old people, ya know? the good stuff
Old Feb 27, 2012 | 09:42 PM
  #93
tboysen00's Avatar
Just read through your thread. Very nice job, it looks like you did everything right and it should be easy to work on. Any updates on the motor? Been to the track? Pics? Anything man... haha sick car.
Old Mar 27, 2012 | 06:27 PM
  #94
01_SOM's Avatar
Hey buddy read your build very nice and clean but i was curious where you ended up mounting the ecu at.
Old Apr 1, 2012 | 03:27 PM
  #95
ebk06's Avatar
I had mine wired up to the Lokar shifter I have. It came with a NSS installed on the shifter already. After 3 used the NSS somehow failed so I bypassed it. Just have to be careful not to start it in gear. Also I highly recommend against any Lokar shifters, total crap and for $250 I cant believe a simple piece like the NSS broke, pure **** all around!!!
No real updates, I need to rewire the started and fans as Im not happy with the way I did them. Ill get some new pics today and post them. Just clay bared, polished and waxed the car a few days ago. I havent taken the car to the track. I need better rear tires. Ill spin through 2nd a lot and it feels downright dangerous when the back end gets squirrely.
I had the wife record this on my phone yesterday. Not quite a WOT run because of traffic and that section of road has terrible traction. I have my cutouts open on this video also but have magnaflow mufflers that quiets the car down a lot when need be. Ill get a better video once I get a gopro, hopefully soon.
Old May 10, 2012 | 09:48 PM
  #96
ebk06's Avatar
Well I rewired the starter and accessories this past weekend. I was having issues with that distribution block I had put in place. The starter was getting heat soaked and with the battery in the trunk the wire to the starter was long. I ran better wire to the starter and routed it to cut off around 6' of wire. I also wrapped the starter in heat shield. The car starts up right away everytime even after a 30 minute drive in 90 degree weather. I also ran the accessory wires directly to the battery and added in a 40 amp circuit breaker. Everything has worked fine and the engine bay is a little cleaner as well. Ill try and get some pics this weekend if it quits raining. Next I need to relocate a coil thats to close to the brake booster and rubbing the spark plug boot on it. I also need to swap in the ported TB Ive had sitting in the garage for the last year lol.
Old Jul 9, 2012 | 12:26 AM
  #97
bakomack's Avatar
If this swap is still on the road I'd like to get some pictures of a few things on the swap if possible.
Can you show me how you did your PVC set up and how did those gauges work out for you? Would you choose something different if you could do it again?
Old Jul 25, 2012 | 11:47 PM
  #98
FastDaddy's Avatar
Thanks for the build thread, just starting the same build with a 4L60. I heard about the shifter, and trans mount issues with this setup already. Looks great, you have encourage me to keep with it. Thanks for all the wiring tips. looking forward to the end results...
Old Aug 4, 2012 | 04:37 PM
  #99
bakomack's Avatar
Where did you get the signal wire from to get the tach working
Old Nov 3, 2012 | 01:31 PM
  #100
ebk06's Avatar
If you check out the diagram I posted up its on there. I think it was a yellow wire off the plug that goes in the back of the stock fox cluster. But all the wiring is laid out for you in this thread somewhere, pretty simple.
