Turbo 5.3 Ford Focus
some specs on it
junk yard 5.3 (just rebuilt it b/c it was blown up when i bought it, i didnt know that till i started it)
ls1 IM, arp rod bolts
master power t76 q trim turbo, custom kit
th400, built, full manual
8.8 4 link mustang rear with qa1's (c-notch b/c the krugel kit doesnt and they sit up like a 4x4)
275 nittos
mustang rack
custom subframe
stock front suspension
megasquirt
Did you use anything from them?
Looks killer, great job.
Lookin forward to this build.
Subd
i bought this engine off a guy that said he was going to swap it into this nova but gave up on the project. it was complete from oil pan to IM and acc and came with harness and ecu. paid 500 for it.
a couple months later after i got it into the car, megasquirt built, and wiring built. i started the engine. it seemed to run ok just had a high idle that i couldnt get down (1k rpm). but it smoked real bad. so i went to diagnosing that... in the end this is what i found....
rebuilt. stock pistons, rods, gm bearings, hastings rings, stock hg, stock head bolts. found a set of comp 918 springs for 50 bucks that i installed... whole rebuild cost me 300
i wanted to spend the least possible on rebuilding the engine i plan to switch to a 6.0 and build it later... i wish i would have bought the 6.0 originally now.. but to late for that.
since the rebuild i have only ran it for about 5 min total. i redid the alt bracket and alt type, had to remove the fans and install them on my DD, and cut the oil pan up. just recently got the oil pan back on, i need to get a new alt (the one i used for moc up had bad bearings), a new belt, and new fans.
the stock ls1 pan i was using had to be moded to get the rack in the right position. i did the cutting and modding. mogan performance welded it for me cause i dont do alum
https://ls1tech.com/forums/conversio...y-mustang.html
