looking for ABS technical info.
Old Feb 4, 2004 | 06:08 PM
70 LS1's Avatar
Conversion master
Default looking for ABS technical info.
Where can I find technical info on the wheel speed sensors used on camaros and corvettes?
Old Feb 7, 2004 | 08:45 PM
ta12sec's Avatar
What do you need to know?
Old Feb 9, 2004 | 12:48 PM
70 LS1's Avatar
Conversion master
I am very interested in adapting the Active Handling/ ABS/ Traction Control from a 2001+ corvette to my 1970.
The trouble I am having is the wheel speed sensors. They are an integral part of the hub/bearing assembly. I have no interest in using the hubs from a C5. Are the sensors different from front to rear? Can I use sensors from a different car? Can the C5 sensors be purchased somewhere separate from the hub? Can you give me the dimensions of the reluctor wheel portion of the sensor?
Old Feb 9, 2004 | 05:18 PM
Scooter70's Avatar
Damn Jeff. It never stops, does it? I think that this project is pretty intense, but also pretty cool. I believe that I have the SAE Tech paper that was written by the GM development engineers after they designed the AH system. If I can't find the printed version, I should be able to download the pdf from SAE directly. (Working for an OEM has its perks sometimes.... free access to all SAE tech papers.)
-Matt
Old Feb 10, 2004 | 11:33 AM
Scooter70's Avatar
Jeff- you've got some mail.
