fuel line sizes???
Old Nov 26, 2010 | 11:16 AM
86 g-body's Avatar
Default fuel line sizes???
Is it standerd to run diff size fuel line between tank/filter/regulator and so on...i see everybody running diff size line on there setup or can i run one size from tank to rails if so what would be a standerd size?? Im running stock ls1 fuel rail,intake,ls2 heads and cam....im thinking about earl superstock pushloc line....
Old Nov 26, 2010 | 07:13 PM
robbyredneck's Avatar
most g body guys will use -6 which translates to 3/8 and keep it the same for the whole send. it's pretty easy to get everybody to mate up that way. -8 send and -6 return is the next step up especially for turbo. right now i have -6 aluminum send and return with an on the regulator and fuel rail side on my lq4 turbo regal. maybe lonnie or nate will chime in
Old Nov 26, 2010 | 07:47 PM
86 g-body's Avatar
Thanks thats what i was looking for now i can make my x-mas list!!!!!!!
Old Nov 26, 2010 | 07:50 PM
Seagram's 72's Avatar
I ran -8 (which was overkill) both feed and return. I can't remember why, but I read many places that sited the reason why you should match return and feed sizes. I know for my large pump, the larger size (-6 or -8) does not hurt.
Old Nov 27, 2010 | 02:08 AM
zipster's Avatar
I ran -6 from the pump to the corvette filter/regulator, then to the fuel rail. I ran -5 for the return off the filter/regulator, its mounted right next to the fuel tank. Engine is n/a lq4.
