Making my Stock Ford tach work with an LS1...
I have a 1988 Merkur XR4ti. I'm planning on installing a LS1 into it.
Its has the typical Ford 4 cylinder tachometer that just uses a green wire ran to the coil to give signal. I've heard you can use Ford 4 cylinder tachs with LS1 electronics.
Is this true? If so please point me in the right direction...
Yes, all Gen III engines use a 4 cyl tach output.
You can also change the output within the tune if it needs to be different because you have a different tach or you can use a signal converter from Dakota Digital. Many options for many needs.
Say it ain't so!!! ^^^
My scan tool and HPT both report about 150 - 200 RPM difference than the tach in my Thunderbird which seems to also react slower than the engine across the RPM range. If I want accurate I'll go aftermarket, but I wanted stealth and low budget.
I got the impression from the OP's first comment an aftermarket or non-factory tach was not on the menu unless it had to be.
Also I plan on having a shift light with the digital tach in it concealed somewhere. Havent decided yet.
