Street and Performance header collectors
I have no way to put it on. the guys at street and performance claim I can put a wrench on the nut. The open ended wrench will only go across half of the distance lengthwise of the nut. The bolt side can get a small 12 point wrench on, but it will only let me turn about 1/8 turn.
I was told to send it back to S&P so they could fix it. I am pretty sure the holes are drilled off of where they should be. I have sent it back and it was returned as is.
I am at wits end. I cant imagine someone making an exhaust piece that would not work with a socket to tighten the bolts up. I would think that if someone was putting it on properly, then a socket would be necessary for torque.
If anyone needs pictures to see what I am discussing, let me know. I am still frame off and putting this on with the body one would even be harder.
T,
lets hope after the exhaust is welded in that the gasket never leaks.
