4L60E what shifter in foxbody
Old Dec 18, 2010 | 11:08 AM
Its Slo's Avatar
Default 4L60E what shifter in foxbody
I've done a few searches and haven't found much. Does anybody have any pics of what shifter will work. Stock location...
Old Dec 19, 2010 | 06:09 AM
nuckifuts's Avatar
I used my stock shifter. Works great and stealthy
Old Dec 19, 2010 | 09:01 AM
Its Slo's Avatar
The stock camaro shifter?
Old Dec 19, 2010 | 10:32 AM
nuckifuts's Avatar
Mustang shifter.
Old Dec 19, 2010 | 10:59 AM
Its Slo's Avatar
Mustang shifter.
no ****. anything special to hook it up and what cable did you use?
Old Dec 20, 2010 | 11:08 PM
Isolde's Avatar
5.0 / AOD shifters don't have enough detents for manual first. If you get the shifter from a 2.3 / A4LD, it has the "extra" detent.
Alternately, B&M can put together a custom version of their console Hammer. Their universal-fit Hammer comes with everything needed to run a 4L60, while the regular console Hammer is a direct fit in the stock center console of the Fox body Mustangs, '87-'93.
Old Dec 21, 2010 | 07:44 AM
sleepy88's Avatar
I got one from a mid 80's thunderbird. it has 4 gear selections so you can manually grab 1st. It looks very much like a factor aod shifter but with 4 gears! I believe there is an escort one like that too.
Old Dec 21, 2010 | 10:39 AM
Its Slo's Avatar
Thanks guys
Old Dec 21, 2010 | 03:25 PM
Isolde's Avatar
Since nuckifuts hasn't answered, I can help this much: B&M does offer an adjustable bracket for the trans, so that different amounts of shifter movement can result in different amounts of detent shaft movement.
You may need a B&M cable, IDK, and they make a bracket to attach their cable to the 4L60.
I probably don't need to spell this next part out, but the idea is for the shifter detents and transmission detents to match up both in park and in manual first.
From there, the rest should be close enough.
Old Dec 21, 2010 | 04:21 PM
sleepy88's Avatar
B&M cable here too
Old Dec 21, 2010 | 10:22 PM
Its Slo's Avatar
Thanks for the info guys. I'll have the mustang next week. I still have to swap k members get headers and get the harness done. hopefully be running in February. I have a friend that sells B&M so I should be good.
Old Dec 13, 2022 | 02:46 PM
mccauley415's Avatar
Default Foxbody Ls swap shifter and cable.
which cable did you use. Do you have any pics? I am having a hard time. I have a 4l60e but I can not get the aod shifter to go into full park. I can get it to go into all the other gears it will just not park. I am using a lokar column shifter rod kit any help or recommendations would be greatly appreciated
Old May 10, 2024 | 03:54 PM
XanderChop's Avatar
I've a similar problem with the Fairmont I'm working on. I used that Lokar rod unit and I tried to bend it up appropriately but it isn't that great. I was hoping to find a solution for a column shift that has that extra position. I really want the look of the stock shifter and be able to grab 1st on the 4L60E. I know this is a late reply to your message and this thread but I wonder if you ever made any head way on this.
~A
Old May 10, 2024 | 04:07 PM
~A
I just kept adjusting and playing with it till it worked the way I wanted it. I still can not get it to go into low/1st but I don’t use low like that so it works for me. I did have to make some customer spacers to get rid of some slop in the linkage connectors. I probably have like 4-6 hours into the adjustments. Be patient and keep at it.
Old May 13, 2024 | 03:58 PM
Tondo's Avatar
B&M came over here
