69 skylark 4 door?
Old Dec 18, 2010 | 06:09 PM
82swbLQ9's Avatar
Default 69 skylark 4 door?
anyone know of frame mounts i can use with the transdapt adapter kit? ive tried tall and narrow frame mounts and the moroso 26510 mounts and none line up. i really dont want to weld mounts on this cars frame as its in extremely nice shape. id rather just bolt some up and throw the motor in.
Old Dec 22, 2010 | 06:46 PM
82swbLQ9's Avatar
guess Im building bolt on perches since i cant seem to find anything wish me luck
Old Dec 22, 2010 | 08:01 PM
deuce4935's Avatar
What about the short and wide design, try those? Maybe if you post pics of what your original mounts look like then someone can chime in with what could work.
Old Dec 22, 2010 | 10:03 PM
82swbLQ9's Avatar
i couldnt use the factory mounting perches as there was a buick 350 in it and it used the lower more inner (towards the firewall ) holes in the frame( 3 bolts ). theres a 4 bolt pattern in the crossmember more forward and up higher of the factory 3 bolt but it must be a buick specific pattern cuz every 4 bolt pattern chevy mount ive tried wont line up. theres 2 bolt patterns on the moroso mount i tried. ive tried chevelle factory mounts for sbc and ive tried a solid tall and narrow mount. ill get a pic in the daylight and post it but im probably stuck building some mounts
Old Dec 23, 2010 | 11:28 PM
deuce4935's Avatar
check out this thread and maybe pm this guy to see what he did for his Buick.
https://ls1tech.com/forums/conversio...ld-thread.html
