Upright Ignition Coil Brackets - Do these look better?
My Pace coil covers came in today. The modification is not to bad. It was about an hour or so worth of work. Here is a post in my build thread with pictures:
https://ls1tech.com/forums/14289194-post75.html
Unwrapping these things totally sucks because the tape they wrap them with is petrified to a concrete hardness.
They are installed already, but I will take them off again when the motor goes in. It is nothing to terribly complex, you just need the proper colored wire and a good soldering set up. Just unwrap the harness, route the wires where you want them, lengthen the ones that don't reach, shrink wrap the new connections and then re-wrap it with high quality electrical tape. The big pain is the damn tape that came from the factory turns into a brittle mess that has to be picked off in pieces in some places. Time consuming and annoying more than anything.
Glad to see someone used a dual plane mani.
