ls1/th400 c10
Old Dec 24, 2010 | 02:09 PM
kaotic_ws6's Avatar
Default ls1/th400 c10
got a question im in need of a proportioning valve for my brakes ( drum no power) and i cant hardly fine the right one for the truck, does anyone know if you can use a universal one? or one from a different vehicle as long as it has the same locations for the brake lines? thanks alot
Old Dec 24, 2010 | 02:38 PM
Carl at CRP's Avatar
I have used the Wilwood adjustable proportioning valve many times, either the 260-10922 or the 260-8419, selection depends on the inlet and outlet sizes You need. Here is a link
http://www.wilwood.com/MasterCylinde...derValves.aspx
to the Wilwood site but they can be purchased from Your favorite vendor here on LS1 tech.
Carl
Old Dec 24, 2010 | 09:58 PM
garys 68's Avatar
As long as you have the correct disc/drum, you're ok.
http://www.speedwaymotors.com/Disc-D...alve,9878.html
Old Dec 25, 2010 | 10:03 AM
kaotic_ws6's Avatar
im drum/drum no power tho
