how fast is a bone stock lq4 coupe? STEP INSIDE...
Old 11-11-2010, 11:51 PM
billyflantos's Avatar
Default how fast is a bone stock lq4 coupe? STEP INSIDE...
i blew my cam only 6.0 up a few weeks ago with the help from a shot of gas and decided to put a bone stock 2006 lq4 with a 100k on the clock to see what it would run in my setup(87 coupe)....heres the results 1.49 60ft 6.96@97 mph...i was pretty suprised of how well it ran with the 1 7/8 headers,victor jr intake,but i did put a smaller 700 double pumper on it...i'm thinking of putting my set of 799 heads on it and then a zo6 cam in it just to see if i could make a run at the stock internal record...what do you guys and gals think?or would this not be considered stock internal?any input would be appreciated....thanks billy
Old 11-12-2010, 08:10 AM
boostnut's Avatar
Thats impressive, are you running a trans brake or manual? What would you expect it to run if you made the full 1/4 pass?
Old 11-12-2010, 09:44 AM
glide with a brake...10.90's to 11.0's in the qtr
Old 11-12-2010, 09:48 AM
dmracing's Avatar
How heavy is your coupe? Do you have a cage or rollbar?
Old 11-12-2010, 09:49 AM
dmracing's Avatar
Oh yeah, also what suspension do you have?
Old 11-12-2010, 09:51 AM
dmracing's Avatar
Sorry, one more thing what size convertor and gear do you run?
Old 11-14-2010, 09:19 AM
did some more testing saturday and got it to go a 6.74@100 with a 1.44 short time...bone stock 100k motor.
Old 11-14-2010, 09:51 AM
key4's Avatar
man thats awesome you faster than me with my cam and ported head 6.0 coupe. I need to roll mine off a cliff I guess.
Old 11-14-2010, 10:22 AM
overhere's Avatar
you must have one hell of a drag setup on that thing! your car moves out like crazy i dont understand it
Old 11-14-2010, 02:18 PM
i noticed it needed to go way up on the two step because it kept nosing over and put some tr55's in it...but other than that i didnt change anything...
Old 11-14-2010, 10:26 PM
quadriplegic's Avatar
Man that's killer. I love that. What does that thing weigh? And what is the bone stock record?
Old 11-14-2010, 11:10 PM
2700lbs..and i dont know what are if there is one for a ls/fox..
Old 11-14-2010, 11:12 PM
4.10,ati 4500,aje stuff on front(150/14 coil over)and upper and lower control arms with a team z anti roll bar with stock shocks for the rear...
Old 11-15-2010, 11:03 AM
rojs234's Avatar
That is fantastic performance, billy!! You never cease to amaze me. I would like to point out something else to the LQ4 guys. You were the first one that I recall mentioning the #799 heads. I have a #799 head in my shop and also a set of brand new ZO6 casting # 243 heads. I had checked the CC's on the 243's at just over 65CC's and then I happened to notice the #799 head has a different and smaller combustion chamber. You can tell just by looking at it. Since the ports are the same as the #243 heads, I would think these would work great on the LQ4's to raise the compression. I didn't have time right then to check the size of the chamber, but I will in the next couple days and report back. I don't know if ALL #799's have these small chambers....these came off a '05 GMC Tahoe 5.3....an aluminum block GEN lV engine. But I would guess you already knew all this..eh, billy?
Old 11-15-2010, 11:25 AM
Dickie-311's Avatar
if i had a transbrake and a 4500 stall i"d be in the 9's also
Old 11-15-2010, 04:34 PM
thanks for the compliments...you ready to turn loose of those l92's yet?
Old 11-15-2010, 04:38 PM
p.s. i tried a dual plane intake when i was testing saturday with this stock 6.0 and it ran with in a hundreth of the victor jr shifting at 6k...so i imagine on a street car with a stick or a tight converter it would be the way to go...thanks billy
Old 11-15-2010, 05:08 PM
Doug G's Avatar
10.7's on a stock 100K mile motor sweet
so a 3400/3500# car would be ???? maybe a mid 11 ???? Good to know....and congrats
Old 11-15-2010, 05:23 PM
rojs234's Avatar
I always thought the dual plane would be close on an engine that most would consider to be a street engine. (an engine turning under 6500 RPM).
I wish you would post that result in the new carb forum. Some of those guys think you need a Vic Jr. on everything from a 3800 lb. truck with 3.50 gears and a stock cam to a 2900 lb. Camaro with a 6 spd. and a 340* @ .050
and deep gears, LOL. And, yes..I'm getting closer to pulling the L92's. One of the questions I was going to ask was what RPM you were shifting at...but you already answered that, and I hope you do try the ZO6 cam before you quit......good info, billy...THANKS! Ron
Old 11-15-2010, 08:32 PM
i'm going to start with the zo6 cam and end up with a more of a mid size cam also...then i'm going to put my 799 heads on it and hopefully i'll have a big motor done for my coupe and can retire this in my 67 camaro... feel free to post it over there if you want to Ron...thanks billy
Quick Reply: how fast is a bone stock lq4 coupe? STEP INSIDE...
