Starting to convert my FD3
Old Feb 8, 2004 | 01:59 PM
LS1/RX-7's Avatar
Default Starting to convert my FD3
Hey guys I am totaly new the forume as you can tell by the # of post I have. I hope to catch on fast about the LS1 and T56.
I have a 93 FD3 (RX-7) that in the next couple of months will be receiving a LS1/T56 conversion. I have a couple of questions that might sound pretty newb but I am totaly unfamiler with the LS1.
1) Is the ECU the same for the auto and the manual tranny. I find a lot of LS1's for sale with the harness and ECU and they dont say if it is a auto or manual ECU. Also I noticed that there are a couple of diffrent 6 speeds out there, do they have their own ECU or are all ECUs compatiable?
2) Does any one have a diagram that shows the shape of the connectors that are need for correct operation of the motor? I would like to go thru and clean up the wire harness of all the connectors that dont need to be there, prefering to do it myself to save some cash.
3) The Vett LS1 is it worth the extra money? If I am correct the WS6,Z28 is 320 hp and the Vett is 340 hp. And will the Z28 oilpan fit on the Vett becuse from what I hear the finned oilpan won't fit into the RX-7.
Is there anyone on here that has first hand experiance with this conversion? I plan to order all my thru Hinsonsupercars here by the end of the month. I was wondering how hard it is to set this up and what kind of performance I can expect from a stock LS1/T56 with the 3.90 LSD.
These are prob just the beggining of the questions.
Thanks for any info.
Old Feb 8, 2004 | 03:56 PM
HotRod68Camaro's Avatar
1) the PROGRAM for the pcm is not the same between a M6 and A4. the 97-98 and the +99 are different also (got different pin outs) http://www.ls1.com/boggs/torques/enginetorques.htm
2) if you want a adiagram the only way u can get it pretty much is by buying a Helms manual.
3) yes the vette produces more power and, the oil pans are interchangeable (had to do it myself). depending on the year it might be worth the money unless you plan on installing aftermarket parts then it probably wont be. the 2002+ came w/ a ls6 intake i believe.
Old Feb 8, 2004 | 04:52 PM
crainholio's Avatar
Huh? Different PCMs for auto trans versus manual?? I dug into PCM compatibility when shopping for a backup PCM for my '01 M6, got a whole spread of vehicles using that same interchange part#. I picked up one from an '02 Avalanche, and one from an '02 Tahoe, both were A4 trans and both were the same GM hardware part#. Software is very different, but that's fixed with an SPS reflash.
Old Feb 8, 2004 | 04:54 PM
yes that is what i ment. the programming is different. sry bout confusion. i will edit my previouos post.
Old Feb 8, 2004 | 05:05 PM
crainholio's Avatar
Cool, I definitely agree with point 2 you made..."hey I don't want to spend the $$ on a Helms, can someone transcribe all the wiring diagrams and connector pinouts?"
Old Feb 8, 2004 | 05:07 PM
yea i hear that, $90 for books. way too much for me but pretty soon im gonna need it so might have to buy them unless somebody does post it.
Old Feb 8, 2004 | 07:06 PM
LS1/RX-7's Avatar
I picked up the service manual for my RX-7 and it was 160$ but that covers every aspect of my car. I dont need a service manual for 99 vett or camaro, but just for the motor. I put a 5.0 in my jeep and was able to get the wiring diagram but there is alot of stuff still in the harness that needs to be cleaned out and I am sure I have stuff cluttering the engine bay that doesent need to be there. There is a harness modification on Ebay for a couple hundred bucks and Hinson also does it for like 400$ I belive and 425$ if you want AC. This conversion is going to cost me around 7500$-8000$ so if I can save some ca$h somewhere along the line the better.
Now crainholio said that the PCM 's are the same but the program can be fixed with a SPS reflash. What is the SPS, and how much is it to have it reflashed? I am assumeing that it is the program in the PCM that is getting rewritten. Would it just be cheaper to buy the PCM with the right SPS to begin with?
Old Feb 8, 2004 | 07:48 PM
crainholio's Avatar
The PCMs aren't *all* the same for *all* LS1s, but within a model year they are. '98 used one model, not sure about '99-00, '01-02 used the same hardware part#. Pinouts can vary, even with the same PCM part#, so make sure your wiring harness and PCM software are the same year.
SPS stands for Service Programming System. There's a good description of it here:
http://www.obd2.com/sps/data/sps.htm
Ken Kelly, author of LS1-Edit, does SPS reflashes for $50 or so...it's not worth buying your own SPS just to do your PCM. That gets you a stock configuration with the right software for your powertrain. Unless you're bringing over VATS and every single sensor in the vehicle, you'll need software tuning to disable these after the SPS reflash.
Old Feb 9, 2004 | 09:17 AM
93LS1RX7's Avatar
All your swap questions can be anwsered at Torquecentral.com. Go to the V8 RX7 section
