New vs re-worked wiring harness
I want something as close to plug and play as possible. Who has the closest thing to plug and play or should I get a new harness? Who makes a new harness that is plug and play?
Thanks for any input
I ended up getting a harness from PSI Conversion. I couldn't be happier - its all new wire, new connectors, and has a fuse/relay box. I didn't want to spend money on a harness but it is just so awesome. I was very happy with my purchase. Check out eBay for their listings.
http://psiconversion.com/product-details.php?id=41
It all sounds chinese to me if someone could point me in the right direction here.. Im running a 01 vett block ls6 heads and intake... with a TH400 trans... Car has all aftermarket gauges, Autometer cobalts... If this helps could someone let me know what harness i should get...
Money saved can go in the bank or put toward goodies for the ride.
Thanks
not sure if they are sponsors, sorry tech if they arent i'm not trying to get in trouble and my bad
All I need to do is connect one wire to a switch power source and one to the battery. Then is you choose, wire up an aftermarket speedo, tach, back up lights and, fuel pump. All of which have wires ready to connect coming off the harness. Of course then you need to connect any aftermarket gauges you have and then fire it up.
