Fox front spring rate?? (coil over)
Old 01-01-2011, 05:10 PM
zapp109's Avatar
Default Fox front spring rate?? (coil over)
Curious what springs/spring rate you guys are running, I just purchased a 87 with ls1 and before i get aligned i may be changing front springs.. Havent checked yet to see what is on the car but they feel very very stiff. This car is going to be a street/strip car. Any input would help
thanks
craig
Old 01-01-2011, 05:19 PM
Dickie-311's Avatar
Originally Posted by zapp109
curious what springs/spring rate you guys are running, i just purchased a 87 with ls1 and before i get aligned i may be changing front springs.. Havent checked yet to see what is on the car but they feel very very stiff. This car is going to be a street/strip car. Any input would help
thanks
craig
i run 14" 150lbs springs in my car
Old 01-01-2011, 06:00 PM
Speedy911's Avatar
I'll be running 175lbs/15" in my Fairmont. Will be iron 5.3 with big turbo. Mostly street, occasional strip.
Old 01-01-2011, 06:45 PM
79LS1FOX's Avatar
Default front springs
I'm running 14" 175lb in my fox with LS2.
Old 01-01-2011, 07:25 PM
ebk06's Avatar
Im running 14" 150lbs.
Old 01-01-2011, 09:27 PM
S10xGN's Avatar
My Maverick is pretty light and I have 450# (coilover) springs. The guys I bought my suspension kit from recommended 550# but after I reminded him that the LS was aluminum, he sent me the 450# and they're perfect.
Old 01-14-2011, 08:21 AM
Isolde's Avatar
It's not just your weight and use, it's also matching the spring rate to your exact shocks.
MM has 2 very helpful pages you should read.
http://www.maximummotorsports.com/st...e=faq_coilover
I can't find the other one, but it tells which brands of coilover shocks like which ranges of spring rates. This page might get you there: http://www.maximummotorsports.com/st...x&cPath=23_374
also,
Mustang drag racers also benefit from installing coil-over conversion kits. Besides the overall reduction in vehicle weight, coil-overs can increase weight transfer by providing bind-free suspension movement and the ability to use relatively soft springs.
Quick Reply: Fox front spring rate?? (coil over)
