LS1 swap into 94 camaro Z28
im swapping in the LS1 into my 94 Z28...im getting a LS1 motor and i have my LT1 T56..i know i can use the T56 with the LS1 front plate, bellhousing, longer shaft, and clutch...im getting the LS1 k member, and steering...now what else do i need?...ive heard that i need LS1 clutch hydrolics, and pedals (do i)?...also would the LS1 T56 fit in my camaro cause i read it wont bolt up lol....also if i get the LS1 computer and harness from a LS1 would i have to fabrictae the harness?..i plan on putting in the 98-02 trans am dash and speedo..thanks
what i really want to know even if u dont agree with it what is every single part and peice i will need for the swap?
You will need Manual Pedals..and yes the complete LS1 Hydraulic System & Clutch setup. Look for a Speed Bleeder while you are at it. The LS1 T56 will bolt right up, just use the LT1 T56 Crossmember.
You will have to build your own Harness..I kept the interior all stock when I swapped my 1995 car.
Here is a thread that will help..many links in there.
https://ls1tech.com/forums/conversio...to-95-z28.html
Hopefully one of the mods will move this to the conversions section..lots more help there.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
'Bird Director
My build thread might help you with a few of your questions:
https://ls1tech.com/forums/drag-raci...p-project.html
So you plan on installing entire dash from an LS transam?? Not sure if that will bolt into your camaro or not. I swapped the entire dash from my 01 camaro into my 96 just because I hate the gauges on 93-96 camaro's. Change you heater core while its readily accessible..
[QUOTE=the_merv;14306358]You will need Manual Pedals..and yes the complete LS1 Hydraulic System & Clutch setup. Look for a Speed Bleeder while you are at it. The LS1 T56 will bolt right up, just use the LT1 T56 Crossmember.
even tho my car is manual i still have to have the LS1 pedals?
no. lt1 pedals work fine. my 93 z28 ls swap has been done since 2005 with zero issues running lt1 pedals.
