Who has extra plugs/pigtails
Hi everyone,
I have a plug with a broken retainer clip in my harness and would like to replace it. Its the connector for the rear VSS in a 4L80E. Its technical name is a "GM Delphi / Packard - 2-way un-shrouded GT 150 3.5mm centerline sealed female pigtail for CLT/VSS". If anyone has one laying around please let me know. I was able to find it on 2 websites and both charge an extra $3.00 because I only need 1. I can't see myself paying a $3.00 fee on a $3.00 part.
All help appreciated,
Mike
Mike
http://www.currentperformance.com/Co...rtec4_5_6.html
With shipping it's like $13. It says the terminals come loose so you may need the terminal pliers. $13 isn't bad considering the price you'd get at the dealership for one would be much more.
It looks just like a regular WSS connector though, if you do work on other GM vehicles, you may want 2 so you can make one into a jumper harness for your DMM
Thanks for the replies fellas. In rooting through my car's trunk this weekend I found a small piece of transmission hearness that was attached when I picked it up from the junk yard. I lucked out beucase it still had the VSS plug on it.
150, 2way, 35mm, 4l80e, centerline, connector, connectors, delphi, electrical, gm, gt, packard, pigtail, pigtails, unshrouded, vss
