oil cooler removal in an lq4
You'll probably have to get rid of them by swapping pans, as the truck pan is going to hang down waaaay low. I swapped to the Hummer H3 pan (LH8) sold as the GM muscle car swap pan, and it's still going to hang down too much, really. I know I have a different car, but the truck pan is really only good in...well, a truck. This pan only saves a little bit, but every bit counts. It was worth it for a new gasket, dipstick, hardware, etc.
http://www.jegs.com/i/GM+Performance...12593/10002/-1
Tossing that pan will solve the cooler line problem now and the hanging-too-low problem you're going to run into later. Aside from that you can get that car 'plate or a piece on ebay that blocks the holes and provides a place to run a pressure line/sender (or you can tap the car plate to run one).
