will a b.o.p tranny bolt to an ls1
Old 01-30-2011, 02:06 PM
G-BUDDY's Avatar
Default will a b.o.p tranny bolt to an ls1
im in the process of doing a gbody swap an a buddy wants to an ls swap also but he has a cutllass and was wondering if his b.o.p tranny will have any issues bolting up to it i know there is a hole you leave out in the th350 to ls and a flexplte spacer other than that will everything else work has anyone done this swap before any info will help thanks
Old 01-30-2011, 03:51 PM
ponjohn's Avatar
No, the chevy vs BOP pattern is different.
One of two fixes, adapter plate or have an Ultra bell installed on trans.
Old 01-30-2011, 11:20 PM
sawzall wielding director
G-Body's Avatar
The answer is yes, sort of. It depends on what trans he has in the cutlass. If its a 200r4 then it should bolt right up because supposedly all of them were cast with a dual bolt pattern housing. If its a BOP housing only trans, then he would have to run an adapter plate.
Old 01-31-2011, 07:36 AM
6806goats's Avatar
Wonder if the 6L80 will fit a BOP engine. Don't see any reason why it would but thought I'd ask. I'll probably change engine and trans in my older Riviera but a 6 sp behind that 430 ci Buick would be cool as well.
Old 01-31-2011, 11:55 PM
G-Body's Avatar
You would have to use the adapter plate, but I don`t see a reason why it would not work.
Old 02-01-2011, 05:52 AM
mt5425's Avatar
Seems it would be easier to just go with a Chev TH400. And I happen to know of a certain someone that has one avail.....
Quick Reply: will a b.o.p tranny bolt to an ls1
