car water pump with truck accessories
Oh and this pump does not have a bolt on back cover, so if I press the truck pulley on, wont it destroy the impeller, or do you pry out the stamped steel plug? Will it ever seal again?
That pump is spaced to clear a VVT cover. Actual spacing is for trucks.
With the pressed on cover, I would not mess with it, just use spacers.
There's another thread where someone pulled the f body pump out 3/4" and used that. Although I've never been able to get off an f body pump without destroying it.
