car water pump with truck accessories
After getting a L92 water pump, and finding out it will not work with my DBW throttle body, I have decide to try a car water pump. It is for 98-02 Camaros. I want to make sure I have what I need, and understand what I have to do.
The pump will need spaced out 3/4" correct?
I will need gaskets on both sides (4 total) correct?
I will need new longer bolts.
Anything else??
Anything else??
That sounds like about it if you are using truck accessories.
You can see the spacers here on fleaBay - check the link for reference only:
http://cgi.ebay.com/ebaymotors/2-LS1...Q5fAccessories
I don't think the pulley sticks out far enough on the F-body (and early Corvette) pumps to mount truck accessories. I am using an early Corvette pump, which I believe interchanges with all F-body pumps, and the pulley barely sticks out far enough to mount my F-body accessories.
http://cgi.ebay.com/ebaymotors/2-LS1-Water-Pump-Spacers-3-4-LS2-LS3-LQ9-LQ4-L92-LY6-_W0QQcmdZViewItemQQhashZitem20b4ccc77fQQitemZ14047 2272767QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccesso ries
Do you guys not press the truck pulley on all the way? Then would just pulling the pulley out about 3/4"work as well, since I don't need a electric fan? Or do you still use spacers? I'm so confused! Also my truck tensioner, is only able two mount with two bolts now
Or do you sue a small spacer and tap the boss for the tensioner?
Doesn't the pulley need to be pressed on all the way down to hold pressure, on the bearings? And if that's not the case won't it work loose being half, on half off, so to speak?
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
![](http://i612.photobucket.com/albums/tt210/04colyZQ8/IMG_0930.jpg)
