O-ring to AN fittings/hydra-boost/power steering
Old 02-06-2011, 08:11 PM
flywheel's Avatar
Default O-ring to AN fittings/hydra-boost/power steering
Ive put the hydra boost valveing on my 71 chevelle and want to run braided hose to the pump. Looks like I need an o-ring fitting in the pump to go to AN hose. Where do I need to go to get them? Ive looked all over. Or is there a better way. Thanks ..
Rick
Old 02-06-2011, 08:27 PM
Bowtie70SS's Avatar
A guy on ebay has all 3 fittings for $28 shipped and they are steel. He also lists the sizes so you could theoretically go to the local hydraulics shop and get them yourself. IMO $28 isn't too bad.
http://cgi.ebay.com/ebaymotors/ws/eB...=STRK:MEWAX:IT
Old 02-06-2011, 08:30 PM
Bowtie70SS's Avatar
Also look in the guy's ebay store he has all of it separately.
Old 02-06-2011, 08:42 PM
LS1MCSS's Avatar
Summit sells o-ring to an fittings. Just pick the ones you want.
http://www.summitracing.com/search/D...?Ns=Rank%7cAsc
Old 02-06-2011, 08:46 PM
bczee's Avatar
Russell makes a 16mm 0-Ring to AN...
Old 02-06-2011, 09:07 PM
Bowtie70SS's Avatar
The ones at Summit are aluminum. I don't know if that really matters but I am going for the steel ones. I emailed them about a complete set. I have a Grand Cherokee box on mine and hydroboost with the Vette pump.
Old 02-06-2011, 09:22 PM
LS1MCSS's Avatar
Summit also sells steel ones. I got mine there for my power steering lines.
Old 02-06-2011, 09:41 PM
flywheel's Avatar
bowtie70, that's just what i was looking for....Thanks man.
Rick
Old 02-06-2011, 09:44 PM
flywheel's Avatar
I have the Jeep Grand Cherekee box also, and a van hydra boost system. New to this LSX stuff. Thanks every one...
Rick
Old 02-07-2011, 06:33 PM
Bowtie70SS's Avatar
I don't buy much from Summit or Jeg's because I live in Ohio. Between the handling fee and tax I can shop on Amazon and compare prices online and get better deals. A lot of times you can ask ebayers and they will make you a deal on several items.
Old 02-07-2011, 08:29 PM
Rick Speed's Avatar
Any body know which sizes i need for a 1979 firebird gearbox...
Old 02-07-2011, 08:35 PM
serpentnoir's Avatar
Default steel fittings
I get all my steel hydroboost fittings from these guys.
The Aeroquip hose is no nonsense. Beats the bulk of the rubber hose.
Old 02-08-2011, 08:14 PM
usc2001gc's Avatar
If budget is in mind, I used 96 Astro hoses on mine. I did have to tweek the metal portion to get it to fit. I'm running a 2005 Corvette LS2, vette accessories, Grand Cherokee Gearbox, Astro Hydraboost with a firewall adapter I purchase from someone on chevelles.com. Purchased the hoses from rock auto for around $20 (found them on clearance). Hoses bolt right up to pump, box, and hydrabooster....no adapters needed.
Attached Thumbnails O-ring to AN fittings/hydra-boost/power steering-212.jpg
Old 02-08-2011, 08:49 PM
Bowtie70SS's Avatar
Your setup looks awesome. Do you have more pics of the engine bay? I was planning on something similar with the PCM on the pass side firewall. I am smoothing it and doing vintage air.
Old 02-09-2011, 04:23 AM
usc2001gc's Avatar
This is the only other picture I have now. (I actually changing up the air intake right now). I'll try to post up more pics this weekend if you'd like, really haven't finished the engine compartment yet. When I paint the car, I think I'm going to paint the inner fenders the same color as the body and hide to wiring harnesses that run to the front of the car behind the fenders.
I used an Old Air Products AC system which comes directly through the firewall. My PCM is mounted inside the car behind the passenger side AC kickpanel. I wanted to keep it hidden and my modified 'vette harness was the perfect length to mount it there.
Attached Thumbnails O-ring to AN fittings/hydra-boost/power steering-213.jpg
Quick Reply: O-ring to AN fittings/hydra-boost/power steering
